Siebel Database Upgrade Guide for DB2 UDB for z/OS > Postupgrade Tasks for Siebel Applications >
Setting Visibility Modes for Access Control
Upgrades: Release 6.2.1 only. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Certain areas of the Release 8.0 default configuration use Catalog visibility. If you want to continue to use Organization visibility, you must make changes to the business component, view, and picklist properties in order to use Organization visibility. This applies to the following objects:
- Business Components with Catalog Visibility
- Applet picklists with Auto Query Mode or New Query set to
None
- Views with Catalog Visibility
After the upgrade, you must carefully evaluate the following business components, views, and picklists, all of which use catalog visibility as the default configuration. Business Components That Use Catalog by Default
The following business components use Catalog as the default pop-up visibility type:
- Banter Resolution Item
- Competitor
- Component Product
- Contact Decision Issue
- Decision Issue
- ERM Internal News Category
- Internal Product
- My Competitor
- My Internal Product
- Recommended Product
- Related Issue
- Sales Tool
- Solution
To change the visibility properties
- Log into Siebel Tools as a valid user.
- Choose the Types tab.
- Choose the Business Component object in Object Explorer.
- Scroll across the list applet to find the property Popup Visibility Type and change this value from Catalog to Organization or to another valid property.
Picklists That Start in Query Mode by Default
The following picklists, by default, start with Auto Query Mode set to New Query or None:
- Asset Mgmt - Internal Product Pick Applet
- CPG Internal Product Pick Applet
- Catalog Admin Category Assoc Applet—Competitor
- Catalog Admin Category Assoc Applet—Decision Issue
- Catalog Admin Category Assoc Applet—Literature
- Catalog Admin Category Assoc Applet—Product
- Catalog Admin Category Assoc Applet—Resolution Item
- Catalog Admin Category Assoc Applet—Solution
- Catalog Admin Category Assoc Applet—Training
- Catalog Admin Category Assoc Applet—eEvents Event
- FS Parts & Tools Pick Applet
- FS Use Plan Products Pick Applet
- Incentive Compensation Product Pick Applet
- Internal Product Pick Applet (eSales)
- Issue Assoc Applet
- Opportunity Management—Product Number Pick Applet
- Opportunity Management—Product Pick Applet
- Order Entry—Line Item Product Pick Applet
- Partner Finder List Applet
- Product Number Pick Applet
- Product Pick Applet
- Product Pick Applet—No Clear
- Product Pick Applet—No Insert
- SR Internal Product Pick Applet
- Sales Tool Pick Applet
- Service Locator List Applet
- Solution Create List Applet
- Training Course Product Pick Applet
- Choose the Applet object in Object Explorer.
- Scroll across the list applet to find the property Auto Query Mode and change this value from
New Query or None to no value.
To change the Auto Query Mode property to have no value, remove any search specification that would otherwise be inherited from the Business Component.
Views That Use Catalog by Default
The following views use Catalog as the default visibility applet type:
- Auction Place Bid
- Competitive Company Across Catalogs
- Decision Issue View
- Products Across Catalogs
- SHP Sales Product View
- SWLS eChannel Solution Display View
- Sales Tools Across Catalogs
- Service Solution List View (SCW)
- Solutions Across Catalogs
- eAuction Auction Item Search View
- Choose the View object in Object Explorer.
- Scroll across the list applet to find the property Visibility Applet Type and change this value from
