Siebel Database Upgrade Guide for DB2 UDB for z/OS > Preparing a Production Environment for a Siebel Upgrade > About Moving the Customized Repository and Schema Definition FilesEnvironments: Production test and Production environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. When you upgraded your development environment, the new customized repository was exported to a file called custrep.dat and the modified schema definition was exported to a file called schema.ddl in the If the development and production upgrades are run on different mid-tier machines, then you must copy the schema.ddl and custrep.dat files to the production mid-tier machine before running the production upgrade. If you modify repository objects or schema definitions after completing the development upgrade (upgphys), you must regenerate the schema.ddl and custrep.dat files. See Regenerating the Siebel Repository Definition Files for further information. You must then copy the files from the development to the production mid-tier machine again. In the production environment, the custrep.dat file is used by the Siebel Upgrade Wizard to import the New Customer Repository and the schema.ddl |
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
