Siebel Database Upgrade Guide for DB2 UDB for z/OS > Creating the Siebel Staging Database >
Removing Interface Tables and Triggers
Once you have build the staging database and prepared the upgrade environment on the z/OS host, the final task to complete before you generate the upgrade files is to remove triggers and EIM/Interface tables from the staging database. The following procedure describes this task. To remove EIM/Interface tables and triggers from the staging database
- On the Staging Database Environment Setup Menu, select option 6: PREGEN Processes, and press Enter.
The Staging Database Pre_Gen Maint. Menu is displayed. The panel ID is SBLPREGP. Options on this panel allow you to generate EIM DROP statements, identify tables with CLOB columns, and generate trigger drops.
- Select option 0: Generate EIM/Interface Table/Tablespace Drops, and press Enter.
- Submit the JCL in the data set
DSNHLQ.SIEBEL.pregen.jcl (PREGEN1). This job generates the EIM, Interface table, and table space DROP statements.
- Verify that the job ran successfully.
Review the output in SDSF or another job output facility. Verify that the RC=0 or RC=4 and that the JCLTEST return code=FLUSH. If you do not see the FLUSH return code, you can verify the condition codes by searching for the condition code IEF206I.
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
- On the Staging Database Pre_Gen Maint. Menu, select option 1. Generate: - List of Tables with CLOB columns - Trigger Drops, and press Enter.
DSNHLQ.SIEBEL.pregen.jcl (PREGEN2). A list of trigger drops and tables with CLOB columns is generated.
- Verify that the job ran successfully. Review the output in SDSF or another job output facility. Verify that the RC=
- On the Staging Database Pre_Gen Maint. Menu, select option 2. Generate: Report of Address Duplicate Rowids, and press Enter.
NOTE: You need to select this option to run jobs to generate a report of duplicate address row IDs only if you are upgrading from SIA 6.2.1 or FINS 7.0.4.
DSNHLQ.SIEBEL.pregen.jcl (ADROWIDS) to generate a report of duplicate address row IDs.
For further information on upgrading address data, see the chapter on preparing application data for upgrade in Siebel Database Upgrade Guide.
- On the Staging Database Pre_Gen Maint. Menu, select option 3: Update Address Report generated log entry, and press Enter.
NOTE: You need to select this option to update address report log entries only if you are upgrading from SIA 6.2.1 or FINS 7.0.4.
- Submit the JCL in the dataset
DSNHLQ.SIEBEL.pregen.jcl (ADRLOGS) to update address report log entries.
- Press PF3 to return to the Staging Database Environment Setup Menu.
- Select option 7: Drop Interface Tables, and press Enter.
DSNHLQ.SIEBEL.install.jcl (PRETIDRP) to drop EIM and Interface tables from the staging database.
This completes the process of creating a staging database. You can now generate the upgrade files.
