Siebel Database Upgrade Guide for DB2 UDB for z/OS > Upgrading the Target Database > Performing the In-Place Target Database Upgrade >
Migrating the Gen Primary 8.0 SQL to Update Data in Target Tables
Perform the following procedure to run the data migration scripts for Gen Primary:
- On the Target Database In-Place Upgrade Menu, select option 10: Gen_Primary Data Migration, and press Enter.
You are placed in edit mode on dataset DSNHLQ.SIEBEL.INSTALL.JCL(SUBGENP).
- Submit the JCL in the dataset to update data in the target tables.
This submits all the Gen-Primary data migration job streams (the number of job streams varies by upgrade type). All of the jobs are run in parallel—no dependencies exist.
- Verify that the job ran successfully. Review the output in SDSF or another job output facility. Verify that the RC=0 or RC=4 and that the JCLTEST return code=
FLUSH. If you do not see the FLUSH return code, you can verify the condition codes by searching for the condition code IEF206I.
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
