Siebel Database Upgrade Guide for DB2 UDB for z/OS > Upgrading the Target Database > Process of Upgrading the Target DatabaseEnvironments: All environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. After you have generated upgrade files against the staging database and prepared the JCL used to run the upgrade processes, you are ready to perform the target database upgrade. This involves the following steps:
For production database upgrades, the additive changes applied to the staging database are applied to the production target database as part of the preupgrade process. The remaining non-additive, schema, unload, load and data migration processes are then applied to the target database as part of the critical path in-place upgrade. For development database upgrades, upgrade changes are applied in one step to the target database during the in-place upgrade. NOTE: The procedures in this chapter use Siebel-Scheduled job execution but you can also choose to use a third party job scheduler. For information on choosing a scheduler, see About Executing Jobs Using Siebel-Scheduled Mode or Vendor-Scheduled Mode. |
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
