Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 > Maintenance Considerations for zSeries > About Siebel Dynamic SQL > Enabling DB2 CLI TracingDB2 Call Level Interface (CLI) tracing can be enabled by adding the following lines to the db2cli.ini file.
[COMMON] One trace file will be created for each thread in the path specified. The path must already exist. On UNIX systems, the DB2 process owner must have the appropriate permissions to be able to write into the directory specified in the TracePathName. The resulting files will be called pid.tid i.e. 382.0 or -23456.0. Only the trace files created at the time of problem recreation should be reviewed. This section can be added into the |
| Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 |
