Product Administration Guide > Customizable Product Rule Designer > Setting Effective Dates for RulesFor each rule you create, you can set effective dates that control when the rule is active. You can set both a start date and an end date. On the start date the rule is used to compute all solutions presented to the user when they configure a product. On the end date, the rule is no longer used to when computing solutions. Specifying start and end dates in combination has the following effects. In the following descriptions, active means the eConfigurator engine uses the rule to compute solutions. Inactive means the rule is not used to compute solutions:
The start date is determined using the Siebel server's system clock. The start and end dates work as follows in relation to the date the product is released (release date):
When you are validating a product, you can temporarily activate or deactivate rules in the current work space by clicking the rule's Inactive box in the Rules List. This lets you simulate how the rule will behave on the start and end date. For example, you can test a rule with a start date in Validate mode using the following process:
You can specify start and end dates for rules when you create them or by editing rules after they have been created. |
| Product Administration Guide |
