Security Guide for Siebel eBusiness Applications > Communications and Data Encryption > Security Considerations for Unicode SupportSiebel eBusiness Applications support Unicode. For comprehensive Unicode compliance, consider the following encryption and authentication issues. Using Non-ASCII Characters in a Unicode Environment
Logging Into a Siebel Application
Encrypted DataSiebel eBusiness Applications provide either AES and RC2 encryption to encrypt field data for sensitive information such as credit card numbers. For encryption with Unicode, you must use either AES or RC2 encryption, rather than the Standard Encryptor, which is no longer supported. For more information, see Configuring Data Encryption. |
| Security Guide for Siebel eBusiness Applications |
