Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading the Database >
Migrating Address Data from Custom Extension Columns
Upgrades:
- From Release 6.x Siebel Industrial applications (except Communications, Media, and Energy) that you are upgrading directly to Release 7.7 Siebel Industrial applications
- From Release 6.x and 7.0.x Siebel Financial Services applications that you are upgrading to Release 7.7 Siebel Industrial applications
- From Release 6.x and 7.7 Siebel eBusiness applications that you are upgrading to Release 7.7 Siebel Industrial applications
- From Release 6.2.1 of Siebel Financial Services applications on IBM z/OS platforms that you are upgrading to Release 7.7.x of Siebel Industrial applications on IBM z/OS platforms
NOTE: This topic does not apply to Siebel eBusiness applications (HOR) that you are upgrading to a later release of Siebel eBusiness applications (HOR).
This topic is part of an upgrade process. See How to Perform the Upgrade. If you have custom extension columns on the Address table S_ADDR_ORG, you must manually edit your upgrade scripts to prevent loss of data during an upgrade. Perform the following task, and contact Siebel Technical Support or Siebel Expert Services if you need assistance. Prerequisite: You must have run the Database Server Configuration utility to pause # 1. This creates the files required for this procedure. To migrate Address data from custom extension columns
- In the tmptable.ctl file, modify the definitions of
S_ADDR_ORG_TMP and S_ADDR_PER_TMP to include your custom extension columns from the development environment.
Here is the path to the file in the Siebel Database Server installation:
Windows: DBSRVR_ROOT\DB2390
UNIX: DBSRVR_ROOT/DB2390
For example:
[Object 2]
Type = Table
Name = S_ADDR_ORG_TMP
Space = USERSPACE1
Column 1 = ROW_ID WVARCHAR(15) NOTNULL
Column 2 = CREATED TIMESTAMP NOTNULL DEFAULT %NOW%
Column 3 = CREATED_BY WVARCHAR(15) NOTNULL
Column 4 = LAST_UPD TIMESTAMP NOTNULL DEFAULT %NOW%
Column 5 = LAST_UPD_BY WVARCHAR(15) NOTNULL
Column 6 = DCKING_NUM NUMERIC(22,7) DEFAULT 0
Column 46 = RURAL_ROUTE_NUM WVARCHAR(10)
Column 47 = START_DT TIMESTAMP
Column 48 = X_CUSTOM_EXTENSION_COLUMN1 WVARCHAR(15)
Column 49 = X_CUSTOM_EXTENSION_COLUMN2 WVARCAHR(15)
- Add all custom extension columns from
S_ADDR_PER and S_ADDR_ORG to the S_CON_ADDR definition.
- In the preschm_sia.sql file, add the custom extension columns for
S_ADDR_PER and S_ADDR_ORG to the migration scripts.
Windows: DBSRVR_ROOT\DB2390\upgrade\version
UNIX: DBSRVR_ROOT/DB2390/upgrade/version
For example:
insert into S_ADDR_ORG_TMP (
ROW_ID,CREATED,CREATED_BY,LAST_UPD,LAST_UPD_BY,
DCKING_NUM,MODIFICATION_NUM,CONFLICT_ID,ACTIVE_FLG,ADDR_NAME,
BL_ADDR_FLG,MAIN_ADDR_FLG,DISA_CLEANSE_FLG,NAME_LOCK_FLG,OU_ID,
SHIP_ADDR_FLG,LATITUDE,LONGITUDE,ADDR,ADDR_LINE_2,
ADDR_LINE_3,ADDR_NUM,ADDR_TYPE_CD,AREA_ID,CITY,
COMMENTS,COUNTRY,COUNTY,DESCRIPTOR,DFLT_SHIP_PRIO_CD,
EMAIL_ADDR,FAX_PH_NUM,PH_NUM,INTEGRATION_ID,INTEGRATION2_ID,
INTEGRATION3_ID,PROVINCE,STATE,TRNSPRT_ZONE_CD,ZIPCODE,
ADDR_MAIL_CD,ADDR_SUB_CD,BU_ID,END_DT,RURAL_ROUTE_NUM,START_DT
,X_CUSTOM_EXTENSION_COLUMN1 , X_CUSTOM_EXTENSION_COLUMN2 )
select ROW_ID,CREATED,CREATED_BY,LAST_UPD,LAST_UPD_BY,
from S_ADDR_ORG
- Edit the preschm_sia.sql
file to populate S_CON_ADDR from the temporary tables with the newly added custom extension columns.
For example:
insert into S_CON_ADDR
(ROW_ID,
CREATED, CREATED_BY, LAST_UPD, LAST_UPD_BY, MODIFICATION_NUM,
CONFLICT_ID, ADDR_PER_ID, ADDR_TYPE_CD, ACCNT_ID,
EMAIL_ADDR, FAX_PH_NUM, PH_NUM, DFLT_SHIP_PRIO_CD,
TRNSPRT_ZONE_CD, BRICK_ID,
SHIP_ADDR_FLG,ADDR_MAIL_CD,BL_ADDR_FLG,END_DT,MAIN_ADDR_FLG,START_DT, X_CUSTOM_EXTENSION_COLUMN1 , X_CUSTOM_EXTENSION_COLUMN2 )
select
s_sequence_pkg.get_next_rowid,
CONFLICT_ID, NEW_ROW_ID, ADDR_TYPE_CD, OU_ID,
TRNSPRT_ZONE_CD , AREA_ID,
FROM S_ADDR_ORG_TMP SAOT
WHERE
NOT EXISTS
(SELECT 'x' FROM S_CON_ADDR SCA1 , S_ADDR_PER TMP
WHERE SCA1.ACCNT_ID = SAOT.OU_ID
AND SCA1.ADDR_PER_ID = TMP.ROW_ID
AND TMP.ADDR_NAME = SAOT.ADDR_NAME
AND SAOT.OU_ID IS NOT NULL
To view the data in your custom extension columns, you must configure your application to expose the custom extension columns added to S_CON_ADDR.
- Development environment upgrades only. In Siebel Tools, add the custom extension columns defined in the previous steps to
S_CON_ADDR and S_ADDR_PER.
NOTE: Confirm that the preschema_sia.jcl file includes all necessary extension columns for the data migration before ftping the file to the zSeries host.
