Upgrade Guide for DB2 UDB for z/OS and OS/390 > Postupgrade Tasks for a Development Environment >
Regenerating the Database Template File
Upgrades: All upgrades. Environments: Development environment only. Following the upgrade, you must regenerate the SQL Anywhere template database file used by Siebel Remote. This process updates its schema to the same version as the Siebel Database Server. You will use the Generate New Database component from a new Siebel Server to do this. For procedures on regenerating the SQL Anywhere Template file, refer to Siebel Remote and Replication Manager Administration Guide.
