Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading a Database from the Mainframe >
Transferring the Customized Repository to z/OS Host
Upgrades: All upgrades. Environments: Production environment only. When you upgraded the custom database schema (upgphys) in your development environment, the new customized repository was exported to a file called custrep.dat, located in the DBSRVR_PLATFORM_ROOT directory on the Siebel Server client machine from which you ran the upgrade. You must now make a copy of custrep.dat and transfer it from your DB2 UDB for UNIX or Windows root directory to your DB2 UDB for z/OS and OS/390 directory on your client machine.
