Select option 2: GEN PRIMARY INDEX REBUILDS.
A series of messages are displayed beginning with the following:
==> SPLIT AND BUILD "SCINDX" INDEX DDL FILES:
DROP INDEXES : DSN=DSNHLQ.SIEBEL.SCINDX.GPDRPIX.DDL
EIM : DSN=DSNHLQ.SIEBEL.SCINDX.EIM.DDL
PRE-GEN_PRIMARY : DSN=DSNHLQ.SIEBEL.SCINDX.GPPRE.DDL
POST-GEN_PRIMARY: DSN=DSNHLQ.SIEBEL.SCINDX.GPPST.DDL
Messages continued:
==> JCL TO RUN DROP/CREATE INDEX "DDL" WRITTEN TO:
DROP INDEXES : DSN=DSNHLQ.SIEBEL.INSTALL.JCL(@GPDRPIX)
CREATE INDEXES : DSN=DSNHLQ.SIEBEL.INSTALL.JCL(@EIMIX)
DSN=DSNHLQ.SIEBEL.INSTALL.JCL(@GPPREIX)
The Split and Build runs next.
The following message appears:
NOTE: FOLLOWING THE MESSAGES BELOW IN APPROX 15 SECONDS, AN "ENTER" PROMPT WILL APPEAR REQUIRING YOUR ENTRY...
These additional messages appear:
DROP STATEMENTS WILL BE BUILT FOR OPTIONAL USE:
BUILDING - DROP DATABASE STATEMENTS
BUILDING - DROP TABLESPACE STATEMENTS
BUILDING - DROP TABLE STATEMENTS
BUILDING - DROP INDEX (UNIQUE ONLY) STATEMENTS
BUILDING - DROP INDEX (NON-UNIQUE ONLY) STATEMENTS
BUILDING - DROP INDEX (OBSOLETE ONLY) STATEMENTS
At the following prompt, enter the maximum number of indexes for a single job.
ENTER THE MAXIMUM NUMBER OF INDEXES TO BE INCLUDED IN A SINGLE REBUILD JOB. (PRESS ENTER TO ACCEPT DEFAULT OF 3, MAXIMUM IS 10)
CAUTION: Consider your objective before choosing a maximum number of indexes for each job. Increasing this number results in fewer jobs but requires more memory and sort work. Reducing this number results in more jobs—reducing resource requirements but building fewer indexes in parallel.
The JCL generation for the Gen Primary Index Rebuilds runs approximately 40 minutes. The following messages appear as the generation runs:
*** => GENERATING INDEX REBUILD JOBS FOR INDEXES TO BE REBUILT "***BEFORE***" GEN_PRIMARY DATA MIGRATION IS RUN
"NEW-SCHEMA" - SIEBEL 7.7 BUILDING "PRE"-GEN_PRIMARY INDEX REBUILDS (GPPREIX)
DSN=DSNHLQ.SIEBEL.SCINDX.GPPRE.JCL
DSN=DSNHLQ.SIEBEL.SCINDX.GPPRE.SQL
The number of generated index rebuilds appears.
NUMBER OF INDEX REBUILD JOBS BUILT = 2226
PROCESSING COMPLETE...
NOTE: Index count varies according to your upgrade path and the number of indexes included in each job.
