Upgrade Guide for DB2 UDB for z/OS and OS/390 > Upgrading a Database from the Mainframe > Preparing the zSeries Host Environment >
Transferring JCL, SQL, and Binary Files to the zSeries Host
The following procedure transfers necessary files to the zSeries host. To transfer files to the zSeries host
- Navigate to your DDL output directory and open the
pretftp.txt file.
Windows: The default DDL output directory is SIEBEL_ROOT\dbsrvr\db2390\dboutput\upgrade.
UNIX: The default DDL output directory is $SIEBEL_ROOT/dbsrvr/db2390/dboutput/upgrade.
- Edit the
pretftp.txt file using the following information:
- Replace
&IP with the IP address or name of your zSeries host, for example ZM01.
- Replace
&Username with the your TSO ID, for example sadmin.
- Replace the constant SIEBELQ1 with your own dataset high-level qualifier (DSNHLQ), for example, to your TSO ID or to a DSNHLQ that you have authority to allocate datasets as (such as
SK.SBL) using a command like Replace All.
Use the same high-level qualifier for all zSeries upgrade datasets. The DSNHLQ must be 18 characters or less and can have multiple nodes separated by periods. A node must be one to eight characters in length. The DSNHLQ can be the TSO ID.
- After modifying the
pretftp.txt file, save it, and then close the file.
- Double-click
pretftp.bat (from UNIX issue the following command: Ftp -i > ftpfile.bat).
- At the prompt, enter the password for the user name that you entered in
pretftp.txt to replace &Username, and then press Enter.
All files generated to this point of the upgrade process transfer from the midtier to the zSeries host.
The pretftp.log file is created in dbsrvr\db2390\dboutput\upgrade.
