Upgrade Guide for DB2 UDB for z/OS and OS/390 > Migrating Siebel 6.x Customizations >
Regenerating the Postmerge Utilities Log
Upgrades: Release 6.x only. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. When upgrading from Release 6.x to Release 7.7, you perform the repository merge and then the Siebel Web Client migration. This invalidates part of the postmerge utilities log created after the repository merge. You must regenerate the postmerge utilities log before using it to evaluate the merge. After the repository merge, the postmerge utilities start automatically. They help resolve common repository merge problems related to configuration and layout. These utilities write to the postmerge utilities log: SIEBEL_TOOLS_INSTALL_DIR\reppatch\log\repreports.log
Prerequisite: You must have run the repository merge and the Siebel Web Client Migration Wizard. To regenerate the postmerge utilities log
- In Siebel Tools, click Tools in the menu bar.
- In the Upgrade submenu, click Upgrade Application.
- In the Merge Repositories dialog box, set up the upgrade in exactly the same way as the actual upgrade, including the advanced settings.
- Click Reports.
- When the process completes, review the log.
