Upgrade Guide for DB2 UDB for z/OS and OS/390 > Migrating Siebel 6.x Customizations >
Reviewing Applet and View Migration
Upgrades: Release 6.x only. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. The Siebel Web Client Migration Wizard and Web Layout Wizard migrate new and modified applets and views to the Siebel Web Client. After running either wizard, review the migrated applets and views. The following issues may require that you remigrate an applet:
- A set of nonfield controls is misplaced or absent in the Web layout.
- The template needs to be changed.
- Field controls are misplaced in the Web layout.
The following issues may require that you remigrate a view:
- The mode of a View Web Template Item is incorrect.
Issues other than those above may need to be resolved manually. For more information on migrating created or modified applets and views to the Siebel Web Client, see About Migrating to the Siebel Web Client. To review applet and view migration
- In Siebel Tools, set the Object Explorer to Flat view and select Applet or View.
- In the list view Comments field, query for
MigN to review new applets or views. Query for MigM to review modified applets for views.
- For applets, sort the resulting list of applets by Class.
- For each applet or view, right-click on it and select Edit Web Layout.
- Review the applet or view layout:
- For applets, use the Applet Web Editor to make any necessary changes.
- For views, use the View Web Editor to make any necessary changes.
- To change the model applet or model view, run the Web Layout Wizard.
