Upgrade Guide for DB2 UDB for z/OS and OS/390 > Postupgrade Tasks for Applications >
Migrating Data to the Bankruptcy Status Field
Upgrades: Releases 7.0.x, 7.5.x, 7.7.x. Environments: Production environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. At Release 7.7, a BK_STATUS_CD column is provided in the S_BANKRUPTCY table. This column stores Bankruptcy status information that is used by the Siebel Financial Services application. If you have implemented a bankruptcy status field in the release you are upgrading from, use an SQL command to migrate the data from the custom extension column to BK_STATUS_CD .
