Upgrade Guide for DB2 UDB for z/OS and OS/390 > Postupgrade Tasks for Applications >
Reviewing Address Records After Upgrade
Upgrades:
- From Release 6.x Siebel Industrial applications (except Communications, Media, and Energy) that you are upgrading directly to Release 7.7 Siebel Industrial applications
- From Release 6.x and 7.0.x Siebel Financial Services applications that you are upgrading to Release 7.7 Siebel Industrial applications
- From Release 6.x and 7.7 Siebel eBusiness applications that you are upgrading to Release 7.7 Siebel Industrial applications
- From Release 6.2.1 of Siebel Financial Services applications on IBM z/OS platforms that you are upgrading to Release 7.7.x of Siebel Industrial applications on IBM z/OS platforms
NOTE: This topic does not apply to Siebel eBusiness applications (HOR) that you are upgrading to a later release of Siebel eBusiness applications (HOR).
Environments: Production environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. The way address data is stored changed at Release 7.7. The upgrade migrated data from the table S_ADDR_ORG to S_ADDR_PER. The upgrade uses the following method for preserving address data:
- If any records have the same value for
ADDR_NAME within or across S_ADDR_ORG and S_ADDR_PER, the upgrade process preserves ADDR_NAME for one of the records and appends the ROW_ID to ADDR_NAME in the others.
- If a record in
S_ADDR_ORG has the same value for ADDR_NAME as a record in S_ADDR_PER, the upgrade process appends the ROW_ID to ADDR_NAME in one of the records.
- The upgrade process truncates the value of
ADDR_NAME to fit the size of the column.
- The upgrade generates a report listing the records with duplicate
ADDR_NAME within and across S_ADDR_ORG and S_ADDR_PER.
After the upgrade completes, review this report and edit or delete records from S_ADDR_PER as desired. NOTE: This report is also generated for 7.0.x Siebel Industry Solutions upgrades to 7.7 Siebel Industry applications. Ignore this report for these upgrades.
To review address records after upgrade
- Review the report generated by the upgrade:
Windows: SIEBEL_ROOT\log\rpt_dup_addr_names.txt
UNIX: $SIEBEL_ROOT/log/rpt_dup_addr_names.txt
- Use the report to identify records that are duplicates.
- Use the application or Enterprise Integration Manager (EIM) to delete or revise records as needed.
