Upgrade Guide for DB2 UDB for z/OS and OS/390 > Postupgrade Tasks for a Production Environment >
Upgrading Siebel Mobile and Dedicated Web Clients
Upgrades: All upgrades. Environments: Production environment only. After a successful upgrade of Siebel eBusiness applications, you are ready to upgrade your Siebel Mobile and Dedicated Web Clients. To upgrade Siebel client software on Siebel Dedicated Web Clients and Siebel Mobile Client workstations
- Uninstall the previous version of the Siebel client application.
- Install the Release 7.7 version of the Siebel client application. You can use either of the following methods for the installation:
- Use the Siebel Image Creator utility to uncompress JAR files and create a Siebel network image, or staging area, for your Siebel applications.
- Use a custom installer created using the Siebel Packager utility. For more information about the Packager utility, see Siebel Installation Guide for the operating system you are using.
NOTE: See Siebel Installation Guide for the operating system you are using for detailed procedures about how to uninstall or install Siebel clients.
