| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Basic Product Administration >
Copying a Product Record
When you copy a product record, all parts of the product definition are included in the copy.
If you copy a customizable product record, the copy includes all the relationships, links, resources, scripts, rules, and user interface.
Use the Copy feature to create product templates. For example, your product line has a two-tiered structure. The first tier contains a half-dozen products that have a similar basic structure. The second tier contains products based on the structure of the products in the first tier.
You could create the first tier by copying a template customizable product 6 times. You would then modify each of the copies to form the first tier. These then become the templates you would use to create the second tier.
To copy a product record
- Navigate to Product Administration.
- Select the product you want to copy.
- From the menu, choose Copy Record.
A new record appears.
- Enter a name for the copy in the Product Field.
- Revise other fields, such as Part # as desired.
- Save the record.
Product Administration Guide Published: 23 June 2003 |
