| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Product Bundles >
Controlling How Bundle Components are Forecast
When you add a product to a bundle, you can put a check mark in the Forecastable field. This adds the product to forecasts when the bundle is included in a quote and the user updates the related opportunity.
To prevent bundle products from being added to product forecasts, do not put a check mark in the Forecastable field in Bundle Administration.
A Forecastable check box is also available in Quotes >Line Items. This allows you to add or remove a bundle and its products from product forecasts within individual quotes.
Product Administration Guide Published: 23 June 2003 |
