| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide >
Select a Configuration Method
There are two approaches you can use to create customizable products. The first approach is a browser-based method and includes eAdvisor. The second approach is a server-based method and uses the eConfigurator rule engine.
Read this chapter carefully and determine which method you should use to create customizable products.
This chapter covers the following topics:
Product Administration Guide Published: 23 June 2003 |
