| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Release and Manage Customizable Products >
Controlling How Customizable Products are Forecast
When you add a component to a customizable product in the Product Designer, a check mark displays in the Forecastable field. This means the component is added to product forecasts when the customizable product is included in a quote and the user updates the related opportunity.
To prevent components from being added to product forecasts, remove the check mark from the component's Forecastable field in the Product Designer.
A Forecastable check box is also available in Quotes >Line Items. This allows you to add or remove a product or component from product forecasts within individual quotes.
Product Administration Guide Published: 23 June 2003 |
