| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Mapping eConfigurator 6.x Features
to Release 7.x >Working with Resources
Resources are implemented in the same fashion for customizable products in
release 7.x as they were for models in 6.x. You define resources in the Resource Designer and then write provide and consume rules that adjust the value of the resource. In release 7.x, you can also provide or consume amounts from a product attribute.In release 7.x, to enforce a resource or attribute so that its value does not drop below zero, you write a configuration rule that constrains the range of allowed values.
Product Administration Guide Published: 23 June 2003 |
