| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Customizable Product Web Templates >
Modifying the Display Name of Groups, an Example
You have a customizable product that has three groups: Group A,
Group B, and Collection C. You want to change the name of Collection C to Group C in the selection pages.Use the Product UI Designer to create the Web pages for configuring the customizable product. Validate the customizable product, and verify that the pages display correctly.
To create a new product theme template and assign it to the customizable product
- In the customizable product Work Space record, click the select button in the Product Theme field and open the dialog box.
- In the Pick UI Style dialog box and write down the filename of the product theme.
- Open the product theme Web template and save it to a new file name: eCfgModifiedTabTheme.swt
- Open the new template and locate the swe.control element. Set
CfgFieldName=".NewGroupName". The first character in the variable name must be a period (.). The variable name must be surrounded by quotes. Save the file.- In the customizable product Work Space record, click the select button in the Product Theme field and open the dialog box.
- Click Add and add the new template.
- Select the template as the product theme template.
To define a UI property for each of the groups
- Open the User Interface Property Designer and select Collection C in the Group section.
- Define a UI property for it as follows:
- Name: NewGroupName. Do not put a period before the name. This is the variable name you inserted in the template file.
- Value: Group C.
- Select Group A.
- Define the UI property for it as follows:
- Value: Group A.
- Select Group B.
- Value: Group B.
- Open the Item Display Properties menu and click Validate.
This starts a configuration session. Verify that the group names display correctly.
Product Administration Guide Published: 23 June 2003 |
