You can use Enterprise Manager to view metrics for the Oracle Voicemail and Fax routing application.
This category contains metrics about the response of the Oracle Voicemail and Fax routing application.
This metric shows the status of the Oracle Voicemail and Fax routing application.
The following table shows how often the metric's value is collected and compared against the default thresholds. The 'Consecutive Number of Occurrences Preceding Notification' column indicates the consecutive number of times the comparison against thresholds should hold TRUE before an alert is generated.
Table 89-1 Metric Summary Table
| Target Version | Evaluation and Collection Frequency | Upload Frequency | Operator | Default Warning Threshold | Default Critical Threshold | Consecutive Number of Occurrences Preceding Notification | Alert Text |
All Versions |
Every 3 Minutes |
After Every Sample |
Not Defined |
0 |
1 |
Routing Application is down |
