Oracle® Retail Predictive Application Server Administration Guide for the Classic Client Release 14.1 E59120-01 |
Previous |
Next |
This appendix describes an RPAS utility called rpac (RPAS Pluggable Automation Component). It can be used to perform various tests on an existing domain, based on a set of test cases contained in XML files.
This appendix contains the following sections:
The rpac utility is used to create highly customizable automated test suites for the RPAS server. The XML-based framework allows rapid development of tests and ensures that test cases can be quickly copied across locations. The flexible XML schema allows the user to test a large number of RPAS features, such as writing data to a domain, building a workbook, running custom menu options, and verifying the results.
The XML framework also introduces consistency, accuracy, and reproducibility in the test results. To reproduce a test case, all that is needed is the XML file and a copy of the domain.
Note that rpac operates directly against the domain itself and therefore does not test any Client/Server interactions.
To run an rpac test, run the following from the command line:
rpac -d <path to domain> -title <title> -input <path to xml input> [commands] [options]
The output of this command is written to unittest.xml in the local directory. The results of this file contain only the tests that have failed. To display both passing and failing tests, use the -coverage option. This generates a coverage.xml in the local directory that contains both passing and failing results.
Required Parameters
Table C-1 Required Parameters
Option | Parameter | Description |
-d |
Path to domain |
Specifies the path to the domain that the test runs against. |
-title |
Title |
Specifies the name that this test run is given in the output files. This is used when combining the results of multiple test runs. |
-input |
path to XML script |
Specifies the path to the XML script containing the test suite. |
Commands
Table C-2 Commands
Command | Description |
<none> |
If you do not specify a command, then rpac will run the test script provided. |
-list |
This command switch provides a listing of all of the tests contain in the XML files. |
-validate |
This command switch validates all the tags and attributes contain in the XML files. |
-printTagDoc |
Switch to enable just printing the tags documentation to the console. |
-writeTagDoc |
Switch to enable writing an xml file 'tagdoc.xml' containing the tag documentation. |
Options
Table C-3 Options
-suite |
pattern |
A regular expression pattern to specify which test suites should be run. Any test suite whose name does not match the pattern is skipped.Example: If you have the following test suites (test1, test2, test3, test4, test5) and you only want to run suites 1, 2, and 4, specify:-suite test[124] |
-coverage |
<none> |
When specified, rpac writes all passing and failing results to coverage.xml. |
-trace |
Log all tags executed. |
-test |
The pattern string of the tests to be run. All tests with a name matching the pattern are run; the rest of the tests are skipped. |
-error |
File name of the directory to contain the XML results file 'unittest.xml' and the optional coverage file 'coverage.xml'. Uses the current directory if not provided. |
The structure of an rpac test script is defined by the following tags.
Table C-4 Test Case Tags
Tag | Description |
<testscript> |
The outermost tag for the test script. This tag contains one or more <testsuite> tags. |
<testsuite> |
This tag defines a suite of tests that are designed to run together. Each suite contains its own <setup>, <teardown>, <testcase>, and <workbook-operations> tags. This tag has a name attribute that can be used with the -suite command line attribute to specify which suites are executed in this run. |
<once> |
The once tag contains tag elements used to set up the environment once before the first test case is executed. It is a tag like setup, but only happens once at the start of a test suite. The once tag has been added to allow a set of measures to be backed up once during the run of the test suite. |
<finalize> |
The finalize tag contains tag elements used to restore the environment after the final test case is executed. |
<setup> |
This tag sets the preconditions that are common to all test cases. Operations inside this tag are run before every test case is executed. Example operations:
<teardown> |
This tag contains cleanup code that is run after all test cases. Operations inside this tag are run after every test case is executed. This is used to restore a domain or workbook to its default state to remove dependencies between independent test cases. Example operations:
<workbook-operations> |
This tag allows the test script to build, refresh, commit, and close workbooks.Workbook operations may exist outside of test cases, but you must encapsulate them wherever possible inside a testsuite tag for logging purposes. |
<testcase> |
This tag is where the code to perform each test goes. It should perform operations, then use the assert tags to verify the results. The name of this tag is used in the output to log timing results and success/failure. Note: Code in the <setup> tag is executed prior to each test case, and code in the <teardown> tag is executed after each test case. |
The optional attribute role for tags testsuite, once, setup and teardown may be required for an rpac application being written for an RDM enable domain. The role assigned to the testsuite tag affects all test cases, and if no role is assigned to once, setup, and teardown, the role assigned to the testsuite tag will affect these tags as well. A role assigned to the once tag is applied to the tags contained in once, and if no role is assigned to setup and teardown, then this role will apply to these tags as well. A role assigned to the setup tag is applied to the tags contained in setup, and if no role is assigned to teardown, then this role will apply to teardown as well. A role assigned to the teardown tag only applies to the tags contain in teardown.
It is recommended that the teardown section restore the domain to its previous state. This removes dependencies between test cases and ensures consistency from one run to the next.
The tags once, setup, and teardown are unique. Only the first occurrence of each of these tags is used. These tags can appear in any order under the testsuite tag, and all of these tags are optional. The code contained in these tags is executed at a set point during the run of unit test code. However, for the tag testcase, the order of occurrence in the testsuite is the order of execution.
This section provides a sample XML file that contains some rpac tests that run against an MFP domain. This test illustrates how the setup and teardown methods work, as well as how to use the various workbook operations.
The first test case demonstrates building the workbook. The first step in this operation is to shell out to the wbmgr utility to clear out all existing workbooks. This step prevents the domain from growing after repeated operations, but you should only use this step in cases where you know that existing workbooks are not needed.
After that, the test verifies the preconditions of the test case. In this example, the test verifies the preconditions performed in the setup code by checking that the domain measure value is "true". After that, the test makes the wizard selections and builds the workbook. Once the workbook is built, an assertion verifies that the load rules correctly set the workbook value.
Once this test case is complete, the teardown code is executed, along with the setup code for the next test case. The test verifies that the teardown code correctly set the workbook's measure value to "false" and then issues a commit. Once the workbook is committed, the domain value is checked to see if it was properly updated. Once again, the teardown code is executed and the setup code is run at the beginning of the next test case.
For the third test case, the setup code should have initialized the domain value back to "true", and the workbook value back to "false". The test case verifies these operations, then performs a workbook refresh and verifies that the workbook value has been correctly set to "true".
After that, the workbook is closed and the test suite is complete.
Note: Because the teardown code modifies workbook data, the workbook close step cannot be encapsulated inside of a test case. If it was, the teardown code would try to modify a workbook that was no longer there and produce a failing result. |
<?xml version="1.0" encoding="UTF-8"?> <!--- Copyright (c) 2004, 2012, Oracle and/or its affiliates. All rights reserved. File: wbtest.xml TestCase Description: - Setup: Set the RPAS Today value Set the domain's measure value to "true" - Teardown: Set the workbook's measure value to "false" - Build: Build a workbook and validate the load rule - Commit: Validate the commit rule - Refresh: Validate the refresh rule - Close the workbook --> <testscript> <testsuite name="MFP RPAC Test 11"> <!--Setup executed at the beginning of every testcase--> <setup> <rpas-today>20070101</rpas-today> <edit-domain-measure-value name="ipopappenbb" namedkeys="h1_2007:100:1" value="true"/> </setup> <testcase name="Enable OP Approval Workbook: Build"> <!--Clear all existing workbooks--> <shell>wbmgr -d [DOMAIN] -remove -all</shell> <!--Verify pre-conditions are true--> <assert-domain-measure-value-eq name="ipopappenbb" namedkeys="h1_2007:100:1" value="true"/> <workbook-operations> <build template-name="EnableOp" label="Enable OP Approval" user="adm"> <!--Make positions selection for the wizard page--> <wizard-page-settings id="wiz_EnableOpssn"> <set-tree-selections control-name="tree1" dim-name="ssn" rollup-name="ssn"> h1_2007 </set-tree-selections> </wizard-page-settings> <wizard-page-settings id="wiz_EnableOpdept"> <set-tree-selections control-name="tree1" dim-name="dept" rollup-name="dept"> 100 </set-tree-selections> </wizard-page-settings> <wizard-page-settings id="wiz_EnableOpchnl"> <set-tree-selections control-name="tree1" dim-name="chnl" rollup-name="chnl" > 1 </set-tree-selections> </wizard-page-settings> </build> </workbook-operations> <!--Validate the load rule worked correctly-> <assert-workbook-measure-value-eq name="ipopappenbb" keys="0:0:0" value="true"/> </testcase> <!--Commit the workbook and assert the measure values in domain--> <testcase name="Enable OP Approval Workbook: Commit"> <assert-domain-measure-value-eq name="ipopappenbb" namedkeys="h1_2007:100:1" value="true"/> <assert-workbook-measure-value-eq name="ipopappenbb" namedkeys="h1_2007:100:1 value="false"/> <workbook-operations> <commit type ="now" template-name="EnableOp" label="Enable OP Approval" user="adm"/> </workbook-operations> <!--Validate the commit rule worked correctly-> <assert-domain-measure-value-eq name="ipopappenbb" namedkeys="h1_2007:100:1" value="false"/> </testcase> <!--Refresh the workbook and assert measure values in workbook and domain--> <testcase name="Enable OP Approval Workbook: Refresh"> <assert-domain-measure-value-eq name="ipopappenbb" namedkeys="h1_2007:100:1" value="true"/> <assert-workbook-measure-value-eq name="ipopappenbb" namedkeys="h1_2007:100:1" value="false"/> <workbook-operations> <refresh template-name="EnableOp" label="Enable OP Approval" user="adm"/> </workbook-operations> <!--Validate the refresh rule worked correctly-> <assert-workbook-measure-value-eq name="ipopappenbb" namedkeys="h1_2007:100:1" value="true"/> </testcase> <!--Close the workbook--> <workbook-operations> <close template-name="EnableOp" label="Enable OP Approval" user="adm"/> </workbook-operations> <!--Teardown executed at the end of every testcase--> <teardown> <edit-workbook-measure name="ipopappenbb" keys="0:0:0" value="false"/> </teardown> </testsuite> </testscript>
When rpac executes, it prints the status of the current execution to the console. Once all the test cases are complete, the summary of test cases is stored in unitest.xml under the current directory. These results contain the failing test case, as well as any error messages that were captured. If -coverage was specified, then a coverage.xml file is generated containing the passing and failing results.
Example:
[rpasHome] rpac -d testDomain -input wbTest.xml -title "'MFP OpApproval RPAC Test" Running rpac tests for RPAC : MFP Tests... Now executing wbmgr in domain. Deleting all workbooks in the domain... Destroying workbook 't0000000000' in domain. wbmgr completed successfully 5.292541 0.308167 0.244300 Ran 3 tests: 0 errors, 0 failures in 5.85 seconds
If something had gone wrong, the output would look like this:
Example:
[rpasHome] rpac -d testDomain -input wbTest.xml -title "'MFP OpApproval RPAC Test" Now executing wbmgr in domain Deleting all workbooks in the domain... Destroying workbook 't0000000000' in domain wbmgr completed successfully Failure 0.192497 Failure Ran 3 tests: 0 errors, 2 failures in 6.42 seconds Contents of unittest.xml After execution, rpac creates a unittest.xml file containing the test results. Here is an example from the successful execution above: <unittest name='MFP OpApproval RPAC Test' runcount='3' timestamp='2012-10-17 10:06:49' elapsedTime='13.72 seconds'> </unittest>
Here is the unittest.xml output from the failing run:
<unittest name='MFP OpApproval RPAC Test' runcount='3' timestamp='2012-10-17 10:07:38' elapsedTime='6.42 seconds'> <failurelist> <failure> <testname> </testname> <message>Got Error: Expected measure 'ipopappenbb' at ArrayKey(0, 0, 0, 0) is false; false == true</message> <file>OpApproval.xml</file> <line>52</line> </failure> <failure> <testname> </testname> <message>Got Error: Expected measure 'ipopappenbb' at ArrayKey(0, 0, 0, 0) is false; false == true</message> <file>OpApproval.xml</file> <line>60</line> </failure> </failurelist> </unittest>
This section provides schema details.
This section provides details about the top-level parent tag.
The setup tag is used to set any preconditions that must be true prior to running each test case. These can include initializing measure values, setting the date, or running batch scripts to prepare the domain.
The teardown tag contains tag elements used to restore the environment to a default state after a test case is executed. This can include returning measures to their default values or running batch scripts to clean up the domain.
The log tag logs a message to the console. It has an optional attribute, msg, containing the message to be logged.
Here is the sample implementation of the above tags
<testscript> <testsuite name="MFP RPAC Test"> <setup> <!--- setup code -> </setup> <testcase name="Measure Analysis Workbook : build"> <!---testcase code -> </testcase > <teardown> <!--- teardown code -> </teardown> <finalize> <log msg="Do Finalize" /> </finalize> </testsuite> </testscript>
This section provides details about generic tags.
The description describes the functionality of each tag and its attributes in tagdoc.xml.
Fail creates a failure message.
Attribute | Description | Category |
msg | Message to be used in the failure text | Optional |
Sets the key specs value of the named key.
name | Key name | Required |
keyspec | Key value spec | Required |
Sets the RpasToday environment variable to the value of this tag. RPAS_TODAY tells RPAS what day that it should think today is.
Sample usage:
Where: the date is given in yyyymmdd format.
The shell tag starts a shell process with the command provided as value of this tag.
working-directory | Directory to use for shell; if not provided then the current working directory is used. | Optional |
check-status | Boolean to determine if a non-zero return status throws an exception. | Optional |
is-shell | Boolean to indicate that the process is a shell. | Optional |
assert-status-equal | Assert return status equals provide value. | Optional |
assert-status-not-equal | Assert return status does not equals provide value. | Optional |
output-file | File to which shell command redirects its output. | Optional |
Sample usage:
<shell check-status="true" is-shell="false">wbmgr -d [DOMAIN] -remove -all</shell>
Registers a measure with the provided properties.
name | Measure name | Required |
Intx | Base intersection | Required |
type | Type of measure | Required |
naval | NA value of the measure | Required |
defagg | Default aggregation | Required |
Sample usage:
<register-measure name="MeasureX" intx="WEEK_STR_DAY_" type="int" defagg="total" naval="0"/>
This section provides details about domain operation tags.
This section provides details about assertions.
Assert a dimension contains or does not contain a position name.
name | Dimension name | Required |
posname | List of comma-separated position names | Required |
containflag | If flag is true, then position names are checked to see if they are contained in the dimension. | Required |
Sample usage:
<assert-dimension-contain name="DEPT" posname="dept1" containflag="true" />
Assert a dimension name exists.
Sample usage:
<assert-dimension-exists name="DEPT" />
Assert a dimension size is between a minimum and a maximum value.
min | Minimum value | Required |
maz | Maximum value | Required |
Sample usage:
<assert-dimension-size name="DEPT" min="8" max="32" />
Assert a domain measure exists.
Sample usage:
<assert-domain-measure-exists name="r_ex_test" />
Assert a domain measure base intersection matches an expected value.
intx | Intersection string to compare with | Required |
Sample usage:
<assert-domain-measure-intx name="r_ex_test" intx="str_sku_week"/>
Assert a domain measure value is equal to an expected value. This tag can be run in a number of ways:
Check against a loadmeasure file:
By specifying <path>, <start>, and <width>, you can validate that the contents of a measure are equal to the contents of a fixed-width loadmeasure file.
Check against specified positions:
By providing <keys> or <namedkeys>, you can verify that all of the positions in your specification are equal to the provided value. You can specify <keyint> to provide positions at an alternate rollup.
Check entire measure:
If you do not supply the <keys>, <namedkeys>, or <path> tag, then rpac will assert that every logical cell in the measure is equal to the value provided.
keys | List of comma-separated position names | Optional |
namedkeys | List of comma-separated position names | Optional |
path | Path to load measure type file to compare with | Optional |
keyint | Intersection string | Optional |
value | Expected value | Optional |
start | Starting column of measure field | Optional |
width | Width of measure field | Optional |
Sample usage (using keys):
<assert-domain-measure-value-eq name="bulylagtx" keyint="year" namedkeys=" 2007" value="Test1"/>
Sample usage (using path):
<assert-domain-measure-value-eq name="bulylagtx" path="loadmeas.dat" start="100" width="20" />
Sample usage (check all):
<assert-domain-measure-value-eq name="bulylagtx" value="Test1" />
Assert a domain measure value is greater than or equal to an expected value. This tag can be run in a number of ways:
<assert-domain-measure-value-ge name="bulylagtx" keyint="year" namedkeys=" 2007" value="Test1"/>
<assert-domain-measure-value-ge name="bulylagtx" path="loadmeas.dat" start="100" width="20" />
<assert-domain-measure-value-ge name="bulylagtx" value="Test1" />
Assert a domain measure value is greater than a an expected value. This tag can be run in a number of ways:
<assert-domain-measure-value-gt name="bulylagtx" keyint="year" namedkeys=" 2007" value="Test1"/>
<assert-domain-measure-value-gt name="bulylagtx" path="loadmeas.dat" start="100" width="20" />
<assert-domain-measure-value-gt name="bulylagtx" value="Test1" />
Assert a domain measure value is less than or equal to an expected value. This tag can be run in a number of ways:
<assert-domain-measure-value-le name="bulylagtx" keyint="year" namedkeys=" 2007" value="Test1"/>
<assert-domain-measure-value-le name="bulylagtx" path="loadmeas.dat" start="100" width="20" />
<assert-domain-measure-value-le name="bulylagtx" value="Test1" />
Assert a domain measure value is less than an expected value. This tag can be run in a number of ways:
<assert-domain-measure-value-lt name="bulylagtx" keyint="year" namedkeys=" 2007" value="Test1"/>
<assert-domain-measure-value-lt name="bulylagtx" path="loadmeas.dat" start="100" width="20" />
<assert-domain-measure-value-lt name="bulylagtx" value="Test1" />
Assert a domain measure value is not equal to an expected value. This tag can be run in a number of ways:
<assert-domain-measure-value-ne name="bulylagtx" keyint="year" namedkeys=" 2007" value="Test1"/>
<assert-domain-measure-value-ne name="bulylagtx" path="loadmeas.dat" start="100" width="20" />
<assert-domain-measure-value-ne name="bulylagtx" value="Test1" />
Assert a domain measure popcount matches an expected value.
pop-count | Expected popcount | Required |
Sample usage:
<assert-domain-popcount-eq name=" Ipopappenbb" pop-count="100" />
Assert a domain measure is not populated.
Sample usage:
<assert-domain-popcount-eq-zero name=" Ipopappenbb" />
Assert a domain measure is populated.
Sample usage:
<assert-domain-popcount-ne-zero name=" Ipopappenbb" />
Assert the dimInfo bitsize or dimregistry bitsize value of a dimension.
name | List of comma-separated dimension
names |
Required |
category | Bit Size Category (dimInfo or
dimRegistry) |
Required |
value | comma-separated Bit Size Values | Required |
Sample usage:
<assert-bitsize-value-eq name="week,skup," category="dimInfo" value="12,14" />
Assert the value for dimension registry version.
value | Registry version | Required |
Sample usage:
<assert-dim-registry-version value="1" />
Assert the threshold value of the dimension.
names |
Required |
value | List of comma-separated threshold
values |
Required |
Sample usage:
<assert-reindex-threshold name="scls,week" value="25,103" />
Assert whether Diminfo Bitsize is equal to DimRegistry Bitsize.
bitsize-flag | Returns true if a Bitsize mismatch occurs | Required |
Sample usage:
<assert-reindex-required name="week" bitsize-flag="false" />
Assert the status of reindex with the user input.
flag | Flag to indicate whether reindexing Domain is in progress. | Required |
Sample usage:
<assert-reindex-in-progress flag="false" />
Set the current domain to either the master or a sub-domain.
index | Domain index | Required |
Sample usage:
< set-current-domain index="0" />
Back up a list of measures.
names | List of measure names | Required |
Sample usage:
<backup-domain-measures names="UTDyDst03U,UTDyDst05U,tdwpunelapbopb,bucpgmpp"/>
This section provides details about domain data edit operations.
Clears all measures used in the following tags: <edit-workbook-measure>, <set-workbook-measure>, <set-domain-measure>.
This sets all the contents of these measures to the NA value.
Clear a domain measure of all data. This sets all the contents of this measure to its NA value.
Sample usage:
<clear-domain-measure name="r_ex_pick_real" />
Clear a list of domain measures of all data.
path | Path to a file containing a new-line delimited list of measures | Required |
Sample usage:
<clear-domain-measure-list path="measlist.txt" />
Execute an expression.
expression | The expression to execute/calculate.
This is a full expression string, |
Optional |
incremental | True if this is to be an incremental
evaluation. |
Optional |
Sample usage:
<execute-expression expression="a = b+c" incremental="false" />
Set the value of a domain measure based on provided
attributes.
incremental | True if evaluation is to be incremental | Optional |
Note: Note that for Date type measures, RPAC supports setting the array cell using either of the following two Date & Time formats - "%m/%d/%Y" or "%m/%d/%Y-%H:%M:%S" where m = 2 digit month, d = 2 digit date, Y = 4 digit year, H = 2 digit hour, M = 2 digit min, and S = 2 digit sec. |
Sample usage:
<set-domain-measure name="r_ex_pick_real" keyint="dept" keys="1" value="150" type="real" />
<set-domain-measure name="meas1" keys="0-2:5" value="0.0" />
Sample usage (using keyint):
<set-domain-measure-value-ne name="meas2" namedkeys="chnl1:week1" value="02/24/2012" />
Sample usage (load-measure file):
<set-domain-measure name="meas1" path="loadMeas1.dat" start="100" width="20"/>
Sample usage (set all):
<set-domain-measure name="meas1" value="2"
Dump a measure to a text file.
path | File path to text file to be used | Required |
noValues | Flag to disable dumping of cell values. | Optional |
Sample usage:
<dump-domain-measure name="utdydst03u" path="test3.txt" noValues="true"/>
This section provides details about workbook operation tags.
This section provides details about workbook wizard operations.
Builds workbook based on provided tag data.
template-name | Template name | Required |
label | Label for workbook | Required |
user | User used to access workbook | Required |
Sample usage:
<build template-name="MeasureAnalysis" label="MEAS AN" user="adm">
Contains the settings for a wizard page.
id | ID use to match up settings with wizard pages. For configured templates, this follows the pattern:
wiz_<wbt_name><base_dim> Example: For the EnableOp workbook, the wizard page that sets CHNL is: Fwiz_EnableOpchnl Note: For custom templates, obtain the name from the administrator. |
Required |
Sample usage:
Sets the selection of a SingleHier Select control of a custom wizard page.
control-name | Name of the control for a wizard page. This can be obtained from the template.cfg file. | Required |
dim-name | Name of the dimension containing the selection. | Required |
selection | Name of the position selected. | Required |
Sample usage:
<set-hier-selection control-name="loc_select" dim-name="chnl" selection="1" >
Sets the value for a Boolean control on a custom wizard page.
control-name | Name of the control for a wizard page. This can be obtained from the configuration | Required |
selected | Set this to TRUE or FALSE | Required |
Sample usage:
<set-selected control-name="UseExtraMeasures" value="TRUE">
Sets the selection of a drop-down list control on a custom wizard page.
control-name | Name of the control for a wizard page. This can be obtained from the configuration. | Required |
selection | Text for the selection operation. | Required |
Sample usage:
<set-selection control-name="ForecastLevel" value="2">
Sets the selections of a list box or tree control on a custom wizard page. This tag should contain a space-delimited list of the selections.
Sample usage:
<set-selections control-name="ExtraMeasures"> meas1 meas2 meas3 </set selections>
Sets the contents of an edit control on a custom wizard page.
control-name | Name of the control for a wizard page | Required |
test | Text for the operation | Required |
Sample usage:
<set-text control-name="MyText" value="abc">
Sets the selections for a two-tree control on either a standard or custom wizard page.
control-name | Name of the control. For two-tree controls, this should always be set to "tree1" | Required |
rollup-name | The highest level of the wizard page. | Required |
dim-name | Name of the dimension on which the selections are made. | Required |
Sample usage:
<set-tree-selections control-name="tree1" rollup-name="chnl" dim-name="str"> str1,str2,str3 </set-tree-selections>
This section provides details about workbook operations.
Does workbook calculations.
Sample usage:
<calc template-name="RptAdmin" label="Reporting Administration" user="adm"/
Checks for the existence of, or executes, a custom menu.
menu-label | Menu label for this custom menu. This can be obtained from the configuration | Required |
menu-exist | Set this to "true" to see if the menu item exists, or leave it blank to execute the custom menu. | Optional |
Sample usage:
<custom-menu template-name="BottomUp" label="Botup" user="adm" menu-label="menuItem83" menu-exist="true"/>
Does workbook refresh.
rule-group | Set this to use a rule group other than the default refresh group. | Optional |
Sample usage:
<refresh template-name="BottomUp" label="Botup" user="adm" rule-group="refresh_alt"/>
Does workbook close. Arguments may be provided for debug purposes.
template-name | Template name | Optional |
label | Label for workbook | Optional |
user | User used to access workbook | Optional |
Sample usage:
<close template-name="BottomUp" label="Botup" user="adm"/>
Does workbook commit.
type | Commit type (now/later) | Required |
Sample usage:
<commit type="now" template-name="BottomUp" label="Bottom Up MFP Refresh" user="adm" />
This section provides details about workbook assertions.
Asserts that the measures provided are visible (or not visible) on the window.
name | Name of the window in the workbook configuration. User-generated windows cannot be used. | Required |
measure | Comma-separated list of measures names. | Optional |
containflag | If true, will check that measures provided are visible. If false, will check that the measures provided are not visible. | Optional |
Sample usage:
<assert-window-contain-measure name=" chnldeptssn__W" measures =" Ipopappenbb"/>
Asserts if a window exists in the current workbook.
name | Window name of current workbook | Required |
Sample usage:
<assert-window-exists name="chnldeptssn__W" />
Asserts window intersection matches provided intersection.
name | Window name of current workbook. | Required |
baseint | Intersection string to compare. Leave blank if checking for scalar. | Optional |
Sample usage:
<assert-window-intersection name="chnldeptssn__W" baseint"chnldeptssn_" />
Asserts if a window does not exist in the current workbook.
Sample usage:
<assert-window-not-exists name="chnldeptssn__W" />
Asserts a measure exists.
Sample usage:
<assert-measure-exists name=" Ipopappenbb" />
Asserts a workbook measure base intersection matches an expected value.
Sample usage:
<assert-measure-intersection name=" Ipopappenbb" baseint"chnldeptssn_" />
Asserts that a workbook measure at the specified positions is equal to the provided value.
Parent tag(s): testcase
Child tag(s): None
keys | The keys to be used to compare measure values. Can be either indices or position names. Each dimension spec in the keys-spec is delimited by a ":". Multiple position ranges for a dimension can be specified by using "," as separators.
When using indices, a range of positions can also be used. Ex - "0-2:4-7,11-13:4" implies indices 0,1,2 for the first dimension, 4,5,6,7,11,12,13 for the second, and 4 for the third dimension of the measure. Note: Because indices are based on the workbook selections, they may not be consistent across all test cases. Care must be exercised to ensure that you are using the correct indices for your specific test case. |
Required |
namedkeys | Position names used to get keys of the measure array. Using indices instead of position names or positions that do not exist in the MeasureStore (Workbook) will be flagged as an error. Similar to "keys" above, but using position names only. | Optional |
path | Path of the flat file used for comparison against the Measure array. This looks like pointing to a pre-set environment variable. "path" cannot be used along with "keys" or "namedkeys". "path" is used only to compare the measure data against a pre-existing flat file. If none of "path","keys" and "namedkeys" are specified, the comparison occurs for all the keys in the measure array of the Measure Store (Workbook). | Optional |
start | The field start value. If this does not exist in the XML, the value will be taken from the measure's properties. Used in flat-file comparison. | Optional |
width | The field start value. If this does not exist in the XML, the value will be taken from the measure's properties. Used in flat-file comparison. | Optional |
value | The expected value of the measure. Comparison on equality. | Optional |
Sample usage: (indices)
<assert-workbook-measure-value-eq name="drwppthrsclsp" keys="0-2" value="0.0" />
Sample usage (names):
<assert-workbook-measure-value-eq name="drwppthrsclsp" namedkeys="pos1,pos2,pos3" value="0.0" />
Asserts a workbook measure value at the specified positions is greater than or equal to the provided value.
Required |
start | The field start value. If this does not exist in the XML, the value is taken from the measure's properties. Used in flat-file comparison. | Optional |
width | The field start value. If this does not exist in the XML, the value is taken from the measure's properties. Used in a flat-file comparison. | Optional |
Sample usage (indices):
<assert-workbook-measure-value-ge name="drwppthrsclsp" keys="0-2" value="0.0" />
<assert-workbook-measure-value-ge name="drwppthrsclsp" namedkeys="pos1,pos2,pos3" value="0.0" />
Asserts a workbook measure value is greater than a provided value.
keys | The keys to be used to compare measure values. Can be either indices, or position names. Each dimension spec in the keys-spec is de-limited by a ":". Multiple position ranges for a dimension can be specified by using "," as separators.
When using indices, a range of positions can also be used. Ex - "0-2:4-7,11-13:4" implies indices 0,1,2 for the first dimension, 4,5,6,7,11,12,13 for the second and 4 for the third dimension of the measure. Note: Because indices are based on the workbook selections, they may not be consistent across all test cases. Care must be exercised to ensure that you are using the correct indices for your specific test case. |
Required |
path | Path of the flat file used for comparison against the Measure array. This looks like pointing to a pre-set environment variable. "path" cannot be used along with "keys" or "namedkeys". "path" is used only to compare the measure data against a pre-existing Flat file. If none of "path","keys" and "namedkeys" are specified, the comparison occurs for all the keys in the measure array of the Measure Store (Workbook). | Optional |
start | The field start value. If this does not exist in the XML, the value is taken from the measure's properties. Used in a flat-file comparison. | Optional |
width | The field start value. If this does not exist in the XML, the value is taken from the measure's properties. Used in flat-file comparison. | Optional |
<assert-workbook-measure-value-gt name="drwppthrsclsp" keys="0-2" value="0.0" />
<assert-workbook-measure-value-gt name="drwppthrsclsp" namedkeys="pos1,pos2,pos3" value="0.0" />
Asserts a workbook measure value is greater than or equal to a provided value.
keys | The keys to be used to compare measure values. Can be either indices, or position names. Each dimension spec in the keys-spec is delimited by a ":". Multiple position ranges for a dimension can be specified by using "," as separators.
Required |
namedkeys | Position names used to get keys of the measure array. Using indices instead of position names, or positions that do not exist in the MeasureStore (Workbook) will be flagged as an error. Similar to "keys" above, but using position names only. | Optional |
path | Path of the flat file used for comparison against the Measure array. This looks like pointing to a pre-set environment variable. "path" cannot be used along with "keys" or "namedkeys". "path" is used only when we want to compare the measure data against a pre-existing flat file. If none of "path","keys" and "namedkeys" are specified, the comparison occurs for all the keys in the measure array of the Measure Store (Workbook). | Optional |
<assert-workbook-measure-value-le name="drwppthrsclsp" keys="0-2" value="0.0" />
<assert-workbook-measure-value-le name="drwppthrsclsp" namedkeys="pos1,pos2,pos3" value="0.0" />
Asserts a workbook measure value is less than a provided value.
Required |
start | The field start value. If this does not exist in the XML, the value is taken from the measure's pProperties. Used in flat-file comparison. | Optional |
<assert-workbook-measure-value-lt name="drwppthrsclsp" keys="0-2" value="0.0" />
<assert-workbook-measure-value-lt name="drwppthrsclsp" namedkeys="pos1,pos2,pos3" value="0.0" />
Asserts a workbook measure value is not equal to a provided value.
Required |
<assert-workbook-measure-value-ne name="drwppthrsclsp" keys="0-2" value="0.0" />
<assert-workbook-measure-value-ne name="drwppthrsclsp" namedkeys="pos1,pos2,pos3" value="0.0" />
Asserts a workbook measure popcount matches an expected value.
Sample usage:
<assert-workbook-popcount-eq name=" Ipopappenbb" pop-count="100" />
This section provides details about workbook data edit operations.
Clears a list of workbook measures of all data.
Sample usage:
<clear-workbook-list path="my_list.txt"/>
Clears a workbook measure of all data.
Sample usage:
<clear-workbook-measure name=" Ipopappenbb/>
Edits the value of a workbook measure based on provided attributes. This tag closely models the action of editing a cell from the Client, as opposed to set-workbook-measure, which does a direct update of the workbook arrays.
This tag can be used in a variety of ways:
Set by loadmeasure file:By specifying <path>, <start>, and <width>, you can set the measure values according to a supplied loadmeasure file. This file must be in fixed-width format.
Set by positions:You can set individual positions by providing a <keys> tag. If you want, you can provide the list of positions at an aggregate level by specifying the intersection using the <keyint> tag.
Set everything:If you do not supply a <path> or <keys> tag, the entire measure will be set to the supplied value.
Note: For Date type measures, RPAC supports setting the array cell using either of the following two Date & Time formats - "%m/%d/%Y" or "%m/%d/%Y-%H:%M:%S" where m = 2 digit month, d = 2 digit date, Y = 4 digit year, H = 2 digit hour, M = 2 digit min, and S = 2 digit sec. |
<edit-workbook-measure name="meas1" keys="0-2:5" value="0.0" />
<assert-workbook-measure-value-ne name="meas2" namedkeys="chnl1:week1" value="02/24/2012" />
<edit-workbook-measure name="meas1" path="loadMeas1.dat" start="100" width="20"/>
<edit-workbook-measure name="meas1" value="2"
Sets the value of a workbook measure based on provided attributes. Unlike edit-workbook-measure, this performs a direct change of the workbook data and does not update the change arrays unless told to do so. This can have an impact on the calculation cycle since bypassing the change arrays results in a full evaluation rather than incremental one.
<set-workbook-measure name="meas1" keys="0-2:5" value="0.0" incremental="true"/>
<set-workbook-measure-value-ne name="meas2" namedkeys="chnl1:week1" value="02/24/2012" />
<set-workbook-measure name="meas1" path="loadMeas1.dat" start="100" width="20"/>
<set-workbook-measure name="meas1" value="2"
This section provides details about dynamic position maintenance tags.
Assert if a position does not exist.
levelname | Level name | Required |
position | Position name | Required |
label | Position label | Required |
lang | Language | Required |
Sample usage:
<assert-position-label levelname="clss" position="4000" label="4000 Casual" lang="english" />
Sample usage:
<assert-position-not-exists levelname="clss" position="4000"/>
Assert if the given rollup is valid or not.
rollup | The expected format for rollup is rollup =childLevel:childPosition, parentLevel:parentPosition | Required |
Sample usage:
<assert-position-rollup rollup="clss:4000,dept:101" />
Assert the status of a position. Status is 1 for formal, 2 for informal, 0 for placeholder, and -1 for deleted.
status | Status | Required |
Sample usage:
<assert-position-status levelname="str" position="str_dpm0000020" status="2"/>
This section contains details about update informal position operations.
tag is the child tag of update-informal-position.
Sample usage:
<dpmposinfo lang="english"> </dpmposinfo>
This is the child tag of dpmposinfo.
isnewpos | Boolean value: True for new position and False for modify. | Required |
label | Position label | Optional |
oldposition | Old position name | Optional |
type | Integer value. Can be one of the following
0, REGULAR: one single position 1, MULTIPLE_PER_PARENT: multiple positions per parent dim 2, ONE_PER_CHILD: one position on rollup dim per child - 3, ONE_FOR_ALL_CHILDREN: one pos on rollup dim for all children 4, GEN_NAME_ONLY: only generating names/labels without applying changes |
Optional |
count | position count for MULTIPLE_PER_PARENT type | Optional |
Sample usage:
<update-informal-positions> <dpmposinfo lang="english"> <dpmposentry levelname="dstr" isnewpos="false" position="801" label="Pos label" oldposition="801" type="0" count="1"/> </dpmposinfo> </update-informal-positions>
This section provides details about HSA tags.
Assert a fact exists or not in the fact group.
factgroup | Fact group name | Required |
factexists | If flag is true, then fact is checked to see if it exists in the fact group. | Required |
Sample usage:
<assert-fact-group name="UtDyScSrc01U" factgroup="utscalar" factexists="true"/>
Assert a fact table exists or not.
exists | If flag is true, then check if the fact table exists. | Required |
Sample usage:
<assert-fact-table factgroup="utscalar" exists="true"/>
Assert a fact value is equal to an expected value.
precision | The number of decimal places to be considered for assertion | Optional |
Sample usage:
<assert-fact-value-eq name="UtDyDstLoU" namedkeys="20070121:30000:5" value="10"/>
Assert a fact value is greater than or equal to an expected value.
Sample usage:
<assert-fact-value-ge name="UtDyDstLoU" namedkeys="20070121:30000:5" value="10"/>
Assert a fact value is greater than an expected value.
Sample usage:
<assert-fact-value-gt name="UtDyDstLoU" namedkeys="20070121:30000:5" value="10"/>
Assert a fact value is less than or equal to an expected value.
Sample usage:
<assert-fact-value-le name="UtDyDstLoU" namedkeys="20070121:30000:5" value="10"/>
Assert a fact value is less than an expected value.
Sample usage:
<assert-fact-value-lt name="UtDyDstLoU" namedkeys="20070121:30000:5" value="10"/>
Assert a fact value is not equal to an expected value.
Sample usage:
<assert-fact-value-ne name="UtDyDstLoU" namedkeys="20070121:30000:5" value="10"/>
Assert a level contains or does not contain a position name.
positions | List of comma-separated position names | Required |
exists | If flag is true, then position names are checked to see if they are contained in the level. | Required |
Sample usage:
<assert-level-contain name="skup" positions="6200006" exists="T"/>
Clears the RDM status code.
status_code | RDM status code | Required |
domain_id | Domain ID | Required |
info | Information | Required |
Sample usage:
<clear-rdm-status status_code="1004" domain_id="" info=""/>
Sets the RDM status code.
Sample usage:
<set-rdm-status status_code="2001" domain_id="0" info="scls"/>
Set the value of a fact based on provided attributes.
value | Value | Optional |
Width | Width of measure field | Optional |
Sample usage:
<set-fact-value name="UtDyDst02U" namedkeys="w01_2007:30018:5" value="0"/>
Reset a sequence generator to a specific value.
name | Name of the generator. | Required |
central | Indicates whether the reset is for centralized generator. True/False. | Optional |
value | Reset to this value. Any integer >=0. Default 0. | Optional |
Sample usage:
<reset-seq-generator name="dpm_str" value="1000"/>
