This chapter provides an overview of developing, deploying, and configuring an Oracle Kodo application using WebLogic Server. The following topics are covered:
Oracle Kodo JPA/JDO is deprecated in this release. Customers are encouraged to consider using Oracle TopLink. For more information about Oracle TopLink, see "Using Oracle TopLink with Oracle WebLogic Server".Oracle Kodo is an implementation of Sun Microsystem's Java Persistence API (JPA) specification and Java Data Objects (JDO) specification for transparent data objects. Oracle Kodo is available as a stand-alone product and is integrated within WebLogic Server.
This chapter describes how to implement an application using JPA or JDO in WebLogic Server. Within WebLogic Server, the JPA and JDO implementations are part of WebLogic Servers overall Enterprise JavaBean 3.0 persistence implementation.
For general information on creating an application using JPA and JDO, see the Oracle Fusion Middleware Oracle Kodo Developer's Guide for JPA/JDO.
The first step in implementing a Oracle Kodo application on WebLogic Server is to write the application code. The following resources provide general information on writing an application that uses Oracle Kodo to manage persistence of your data:
Once you are familiar with the steps involved in creating applications using Oracle Kodo and have created your application, the following sections describe how to deploy and configure your application using WebLogic Server.
If you choose to use a different version of Oracle Kodo than the one provided by default within WebLogic Server, you must use the FilteringClassLoader to specify the packages—in this case Oracle Kodo and OpenJPA— that you want to be loaded from the application, and not from the system classloader.
The following example shows how to load the Oracle Kodo and OpenJPA packages from the application using weblogic-application.xml:
<prefer-application-packages> <package-name>org.apache.openjpa.*</package-name> <package-name>kodo.*</package-name> </prefer-application-packages>
For more information on filtering classloaders, see "Understanding WebLogic Server Application Classloading" in Oracle Fusion Middleware Developing Applications for Oracle WebLogic Server.
Then, you can package the Oracle Kodo and OpenJPA packages with your application using the library directory, as described in "Library Directories" in Oracle Fusion Middleware Developing Applications for Oracle WebLogic Server.
The following sections describe how to configure persistence.
Oracle Kodo uses two XML files, listed in the following table, to define configuration properties.
Table 7-1 Persistence Configuration Files
| Configuration File | Description |
Oracle Kodo configuration parameters defined by the JPA functional specifications. This file is required. The XML schema for structuring this configuration is available at: For more information, see "Chapter 6. Persistence" in the Oracle Fusion Middleware Oracle Kodo Developer's Guide for JPA/JDO. |
Configuration parameters that are specific to Oracle Kodo. This file is not required when deploying an application. If specified, you must still provide a If you do not include The XML schema for structuring this configuration is available at: Note: The |
Edit the contents of the configuration files as required to configure persistence. Persistence units can be packaged as part of a WAR or EJB JAR file, or can be packaged as a JAR file that can be included in a WAR or EAR file. The files should be available as resources in the META-INF directory of the root of the persistence unit. For container environments, the root of a persistence unit may be one of the following:
EJB-JAR file
WEB-INF/classes directory of a WAR file
JAR file in the WEB-INF/lib directory of a WAR file
JAR file in the root of the EAR
JAR file in the EAR library directory
Application client jar file
The following provide considerations for using the configuration files together.
When using the persistence-configuration.xml file, all Oracle Kodo-specific properties must be included in the persistence-configuration.xml file and not the persistence.xml file. In this case, the WebLogic Server Administration Console and WebLogic Scripting Tool (WLST) recognizes the persistence unit as a Oracle Kodo persistence unit and provide advanced configuration and tunables support.
If Oracle Kodo-specific properties are included in the persistence.xml file, the persistence unit will be treated as a third-party persistence unit by the Administration Console and WLST.
If the persistence-configuration.xml descriptor is available and contains an entry for a given persistence unit, then no Oracle Kodo (kodo) or OpenJPA (openjpa) properties can be specified in the <properties> tag of the persistence.xml file for that persistence unit.
Because Oracle Kodo is a highly customizable environment, many configuration properties relate to the creation and configuration of system plugins. Plugin properties have a syntax very similar to that of Java annotations. They allow you to specify both what class to use for the plugin and how to configure the public fields or bean properties of the instantiated plugin instance.
Essentially, plugins are defined using a series of properties using name/value pairs. For example, the following shows how a plugin is defined within persistence.xml:
<properties> <property name='myplugin.DataCache' value='com.bea.MyDataCache(CacheSize=1000, RemoteHost='CacheServer)'> </properties>
Before you deploy a Oracle Kodo application, you must perform the following tasks:
Create a Oracle Kodo application, as described in Creating an Oracle Kodo Application.
Configure persistence, as described in Configuring Persistence.
Created and archive for your application (.ear or .war).
Once completed, you are ready to deploy your application on WebLogic Server. Once your application is configured, a Oracle Kodo application is deployed just like any other application. For complete information on deploying applications, see Oracle Fusion Middleware Deploying Applications to Oracle WebLogic Server.
You cannot create a new persistence unit from the Administration Console. To create a new persistence unit, you must editpersistence.xml manually.Once you have deployed your Oracle Kodo application, you can alter the configuration parameters defined in persistence.xml and persistence-configuration.xml.
The following sections describe how to configure a Oracle Kodo application with or without using the Administration Console.
If your deployed application has defined a persistence unit within persistence.xml, you can access configuration from within the Administration Console using the following:
Select Deployments.
Select the name of the module containing a persistence unit that you want to configure.
Select the Configuration tab.
Select the Persistence tab.
From the list of persistence units, select the one that you want to configure.
From here, you can access all of the Oracle Kodo persistence parameters that can be edited from the Administration Console.
If you need to alter parameters that are not available using the Administration Console, use one of the following methods:
Manually edit the persistence.xml and persistence-configuration.xml files that are archived with the application.
Use the SessionHelper to access and configure the deployment plan. For more information, see "SessionHelper" in "The Tools Package" in "Understanding the WebLogic Deployment API" in Oracle Fusion Middleware Programming Deployment for Oracle WebLogic Server.
Use the WLST loadApplication() method to load and update the application deployment plan. For more information, see "Updating the Deployment Plan" in Oracle Fusion Middleware Oracle WebLogic Scripting Tool.
Manually edit your deployment plan. For more information, see "Manually Customizing the Deployment Plan" in "Exporting an Application for Deployment to New Environments" in Oracle Fusion Middleware Deploying Applications to Oracle WebLogic Server.
