This chapter provides an overview of PeopleSoft Enterprise HRMS and discusses:
PeopleSoft Enterprise HRMS integrations.
PeopleSoft Enterprise HRMS implementation.
PeopleSoft Enterprise HRMS Overview
PeopleSoft HRMS is an integrated suite of applications and business processes that are based on PeopleSoft’s Pure Internet Architecture (PIA) and enterprise portal technologies.
The sophisticated features and collaborative, self-service functionality available in PeopleSoft HRMS enable you to manage your human resources from recruitment to retirement while aligning your workforce initiatives with strategic business goals and objectives.
PeopleSoft Enterprise HRMS Integrations
PeopleSoft HRMS integrates with other PeopleSoft applications, such as PeopleSoft Enterprise Financials, PeopleSoft Enterprise Workforce Analytics, and PeopleSoft Enterprise Learning Management. PeopleSoft HRMS also integrates with other third-party applications. PeopleSoft HRMS uses various integration technologies to send and receive data.
We discuss integration considerations in the implementation chapters in the PeopleBooks. Supplemental information about third-party application integrations is located on the PeopleSoft Customer Connection website.
PeopleSoft Enterprise HRMS Implementation
PeopleSoft Setup Manager enables you to generate a list of setup tasks for your organization based on the features that you are implementing. The setup tasks include the components that you must set up, listed in the order in which you must enter data into the component tables, and links to the corresponding PeopleBook documentation.
PeopleSoft HRMS also provides component interfaces to help you load data from your existing system into PeopleSoft HRMS tables. Use the Excel to Component Interface utility with the component interfaces to populate tables.
This table lists all of the components documented in the PeopleSoft Enterprise HRMS 9.0 Application Fundamentals PeopleBook that have component interfaces:
Component |
Component Interface |
References |
Departments component (DEPARTMENT_TBL) |
DEPARTMENT_TBL |
Establishment component (ESTABLISHMENT_DATA) |
ESTABLISHMENT_DATA |
Job Code Task Table component (JOBCODE_TASK_TABLE) |
JOBCODE_TASK_TABLE |
See Defining Job Tasks. |
Job Code Table component (JOB_CODE_TBL) |
CI_JOB_CODE_TBL |
See Classifying Jobs. |
Job Task Table component (JOB_TASK_TABLE) |
JOB_TASK_TABLE |
Location component (LOCATION_TABLE) |
LOCATION_TABLE |
FLSA Calendar Table (FLSA_CALENDAR) |
FLSA_CALENDAR |
Pay Run Table (PAY_RUN_TABLE) |
PAY_RUN_TABLE |
See Creating Pay Run IDs. |
Tax Location Table component (TAX_LOCATION_TBL) |
TAX_LOCATION_TBL |
See Also
Enterprise PeopleTools PeopleBook; PeopleSoft Setup Manager
PeopleSoft Enterprise Components for PeopleSoft Enterprise HRMS and Campus Solutions 9.0 PeopleBook
