This chapter discusses how to:
Define citizen status codes.
Define national ID types.
Set up additional name information.
Define address types.
To define citizen status codes, use the Citizen Status component (CITIZEN_STATUS).
This section discusses how to define citizenship statuses.
Page Name |
Object Name |
Navigation |
Usage |
CITIZEN_STATUS |
Set Up HRMS, Foundation Tables, Personal, Citizen Status, Citizen Status Table |
Define the citizenship statuses you’ll need to track for various countries. For example, you may need to distinguish between a native, a naturalized citizen, or a permanent resident of a particular country. |
Access the Citizen Status Table page.
Country |
The system displays the country code you entered to access the page. Define citizenship status codes for this country. |
Status |
Enter the citizenship status code that you want to define. Enter as many citizenship codes as needed. |
To define national ID types, use the National ID Type component (NID_TYPE_TABLE).
This section discusses how to assign a national ID type to a country code.
Page Name |
Object Name |
Navigation |
Usage |
NID_TYPE_TABLE |
Set Up HRMS, Foundation Tables, Personal, National ID Type, NID Type Table |
Assign a national ID type to a country code and provide a default or a dummy national ID for a country to use when a person or applicant ID is unavailable. |
Access the National ID Type Table page.
All countries track some form of national ID for payroll, identification, or benefits purposes. For example, German workers are assigned a Social Insurance number, UK workers have a National Insurance number, and U.S. workers have a Social Security number. Each type of national ID has unique formatting requirements.
When you select a country code on any global page where you are entering a national ID, the system refers to the information defined on this page to enter a default national ID type (if selected) or to ensure that you select a valid one. The system also validates the national ID you enter against the format you specify here. If you don't enter the correct number of digits or letters for a country's national ID, the system displays a warning message.
For example, when you enter national ID information for a new American person on the Biographical Details page the system uses the information set up on the National ID Type Table page to determine the valid national ID types for USA and enters PR as the default. It will validate the data you enter to make sure it matches the specific value types you set up for the National ID Type Format and format the data entered, if necessary. In this example, the system will reformat an entry of 999999999 to 999–99–9999.
Note. Application pages containing the National ID field perform an additional system check to determine the proper display by referring to the User Defined File (UDF) format. Specify these formats in PeopleSoft Application Designer.
Note. PeopleSoft delivers the National ID Type Table with the proper types for BEL, CAN, DEU, CHE, ESP, FRA, GBR, ITA, JPN, MEX, NLD, and USA.
Note. (GBR) Use the NID Prefix GBR page to define valid national insurance prefixes. The Inland Revenue requires that employers' year-end reporting contain valid national insurance prefixes only.
See (GBR) Setting Up National Insurance Prefixes for the U.K..
Note. (CAN, USA) The delivered proper national ID type for Canada and the United States is PR (which corresponds to the Canadian Social Insurance Number and the American Social Security Number, respectively). You cannot delete this value because it is required for payroll processing.
Note. (DEU, JPN) Users in Germany and Japan aren't required to enter national ID data for workers, so PeopleSoft created a default value of NO .
NID Type (national ID type) |
Enter the types of national IDs you will use to identify people (for example, employees, dependents, and applicants). If you do not require a national ID type for a country, create a value of NO and leave the National ID Format field blank. National ID Type is often a required field on other PeopleSoft HRMS pages and this gives you a value to enter for individuals from this particular country. |
Default |
Select to have the system use this NID Type as the default national ID type for individuals from this country. You do not have to designate a default national ID type for a country but without a designated default users will need to specify a type every time they enter a national ID in the system. |
National ID Format |
Indicate the default format for the national ID. Use the following values:
Note. In addition to the general formatting you set up here, PeopleCode record logic performs special data validation on BEL, BRA, CAN, CHE, FRA, GBR, MEX, NLD, USA, DEU, ESP, MYS, and ITA national IDs. Note. (USA) When reporting to U. S. federal government agencies, PeopleSoft Enterprise Payroll for North America converts the default for missing or unknown Social Security numbers to the format required by the agency. |
NID as stored (national ID as stored) |
Shows how the NID is stored in the system. Match this value to the field display formats in the Application Designer. |
See Also
Entering Name and Biographical Data
To set up additional name information, use the Name Format Types component (NAME_FORMAT_TBL), Name Type component (NAME_TYPE_TBL), Name Prefix component (NAME_PREFIX_TABLE), Name Suffix component (NAME_SUFFIX_TABLE), Royal Name Prefix component (NM_ROYAL_PREF), Name Royal Suffix (NM_ROYAL_SUFF), and Name Title component (TITLE).
This section provides an overview of additional name information and discusses how to:
Enter name format types.
Enter name types.
Enter name prefixes.
Enter name suffixes.
Define royal name prefixes.
Define royal name suffixes.
Whether you’re managing a global workforce or a workforce in a single country, you’ll need to track a variety of names and titles as part of your records. With the Name Prefix, Name Suffix, Name Royal Prefix, Name Royal Suffix, and Title tables, you can define standard name prefixes like Mr. or Mrs. or Mdme. and Mssr., and suffixes like Jr. and Sr.
If you’re managing a European workforce, you can track additional standard naming conventions for Germany and the Netherlands, such as the royal name prefix von for German workers. You can also track formal titles such as professor, doctor, or count. These tables provide you with a flexible method for tracking a wide variety of naming conventions in your human resources system.
Page Name |
Object Name |
Navigation |
Usage |
NAME_FORMAT_TBL |
Set Up HRMS, Foundation Tables, Personal, Name Format Types, Name Format Tbl |
Define name format types to use on name pages throughout HRMS. |
NAME_TYPE_TBL |
Set Up HRMS, Foundation Tables, Personal, Name Type, Name Type Table |
Define name types and the order in which they are available. |
NAME_PREFIX_TABLE |
Set Up HRMS, Foundation Tables, Personal, Name Prefix, Name Prefix Table |
Enter name prefixes that you’ll use when you record name information. |
NAME_SUFFIX_TABLE |
Set Up HRMS, Foundation Tables, Personal, Name Suffix, Name Suffix Table |
Enter name suffixes to use to record name information. |
NM_ROYAL_PREFIX |
Set Up HRMS, Foundation Tables, Personal, Royal Name Prefix |
Enter royal prefixes and descriptions. Name Royal Prefix codes are used primarily for Germany and the Netherlands. When you enter names for workers in the Personal Data pages, you can reference these standard name prefixes. |
NM_ROYAL_SUFFIX |
Set Up HRMS, Foundation Tables, Personal, Royal Name Suffix |
Define royal suffixes. The Name Royal Suffix application is used only by Germany and prompts with DUEVO standards. When you enter names in the Personal Data pages, you can reference these standard name royal suffixes. |
TITLE_TBL |
Set Up HRMS, Foundation Tables, Personal, Name Title |
Enter titles for use with names. Track standard titles—from professor to mijnheer —for names in your human resources system. |
Access the Name Type Table page.
Order by |
Enter the order in which the system should make this name type available. |
Name Type CD (name type code), Name Type, and Short Name |
Enter a code for the name type, the full name type name, and a short version of the name type. |
Note. You cannot edit the Primary and Preferred name types because they are system data.
Access the Name Prefix Table page.
Name Prefix |
Enter the name prefix you want to add. When you enter names for people in the Personal Data pages, you can reference these standard name prefixes. The system displays the prefixes you enter here as part of the person's name. Note. Name prefixes aren’t effective-dated, nor do they have a status associated with them. |
Access the Name Suffix Table page.
Name Suffix |
Enter the name suffix you want to add. When you enter names for people in the Personal Data pages, you can reference these standard name suffixes. |
Short Description and Description |
Descriptions you enter for the prefix appear on the page as part of the person’s name. |
Note. Name suffixes aren’t effective-dated, nor do they have a status associated with them.
Access the Royal Name Prefix page.
Certified By |
Displays the value you selected when you accessed the page: DUEVO for German prefixes or NEN for Dutch prefixes. |
Name Royal Prefix |
Enter a royal prefix name, using up to 15 characters. |
Status |
Name Royal Prefixes aren’t effective-dated, so to retire a prefix code, change the status to Inactive. |
Access the Name Royal Suffix page.
Certified By |
The system displays the value you selected to access the page: DEUVO for German prefixes or NEN for Dutch prefixes. |
Name Royal Suffix |
Enter a name royal suffix, using up to 15 characters. |
Status as of Effective Date |
Name royal suffixes aren’t effective-dated, so to retire a suffix code, change the status to Inactive. |
To define address types, use the Address Type component (ADDR_TYPE_TBL).
This section discusses how to enter address types.
Page Name |
Object Name |
Navigation |
Usage |
ADDR_TYPE_TBL |
Set Up HRMS, Foundation Tables, Personal, Address Type, Address Type Table |
Enter address types and the order in which they are available. |
Access the Address Type Table page.
Order by |
Enter the order in which the system should make this address available. |
Addr Type CD (address type code), Address Type, and Short Type |
Enter a code for the address type, the full address type name, and a short version of the address type. |
Note. You cannot edit the Home, Mailing, Business, and Check address types because they are system data.
