Administering the HRMS System
This chapter discusses how to:
Click to jump to parent topicAnalyzing Portal Navigation
To analyze portal navigation, use the Portal Analysis component (RUNCTL_PORTAL).
This section discusses how to analyze HRMS portal navigation.
Click to jump to top of pageClick to jump to parent topicPage Used to Analyze Portal Navigation
Page Name
Object Name
Navigation
Usage
Portal Analysis
RUNCTL_PORTAL
Set Up HRMS, System Administration, Utilities, Portal Analysis, Portal Analysis
Analyze the portal navigation structure for users, roles or permission lists.
Click to jump to top of pageClick to jump to parent topicAnalyzing Portal Navigation
Access the Portal Analysis page.
File Name
Enter the name of the file you want the process to create and populate with the portal analysis. The process will distribute the file to the reporting repository.
Portal Name
Enter the name of the portal you want to analyze.
Content Provider Name
Select HRMS in the Content Provider Namefield to analyze HRMS portal navigation.
Process Result
Select the processing result from the following options:
  • Portal/Menu Path
    The result creates a straight list of the portal and menu paths. This result does not use the other values on the page so the system hides them when you select this option.
  • Portal Navigation Hardcopy
    This result gives you more options and can create a more hierarchical view of the navigation.
Portal Object Name
Select the portal object name.
Display Levels
Enter the number of portal levels to print. Leave empty to print all the levels.
Show Object Names
Select to display the object names of the CREFs or folders.
If you leave this check box clear, the process will just display the labels.
Show Menu.Component.Market
Select to display the CREFs menu, component, and market information.
Suppress Hidden Objects
Select to keep the process from including hidden objects.
If you leave this check box clear, the system identifies hidden objects with the following text preceding the object name: *hidden*.
Apply Security Based On
Select to analyze the portal navigation for the security access assigned to a UserId, Role, or Permission List. Select the userID, role, or permission list to use.
Click to jump to parent topicRestricting the Deletion of IDs
To restrict the deletion of IDs, use the ID Delete Control component (ID_DEL_PRVNT_TABLE).
This section discusses how to prevent the deletion of IDs from critical records.
See Also
Changing and Deleting IDs
Click to jump to top of pageClick to jump to parent topicPage Used to Restrict the Deletion of IDs
Page Name
Object Name
Navigation
Usage
ID Delete Control
ID_DEL_PRVNT_TABLE
Set Up HRMS, System Administration, Database Processes, ID Delete Control, ID Delete Control
Enter records from which an ID should not be removed during an ID deletion or change. This ensures that the information is stored for historical purposes.
Click to jump to parent topicRefreshing and Auditing Human Resources Data
To refresh and audit Human Resources data, use the Refresh EMPLOYEES Table component (RUN_PER099), PERSONAL_DATA Settings component (PERSON_DT_SETUP), Refresh Personal Data component (RUN_PERS_REFRESH), Update Personal Data-Future component (RUN_PERSDATA_FUT), Refresh Name Display Values component (NAME_DISPLAY_RC), and the Core HR Data Integrity Audit component (RUN_PER900).
See Also
Refreshing Tables to Facilitate Reporting
Click to jump to top of pageClick to jump to parent topicPages Used to Refresh and Audit Human Resources Data
Page Name
Object Name
Navigation
Usage
Parameters
RUNCTL_ASOF_DATE
Set Up HRMS, System Administration, Database Processes, Refresh EMPLOYEES Table, Parameters
Refresh the PS_EMPLOYEES snapshot table as of the selected date.
PERSON_DT_SETUP
Set Up HMRS, System Administration, Database Processes, PERSONAL_DATA Settings, PERSONAL_DATA Settings
Select the data that you want to include in the refresh snapshot of the Personal Data component (PERSONAL_DATA). The fewer options you select, the faster the system can refresh the table. You must make these selections when you install HRMS.
PeopleSoft only uses EmplID and Name data. Select the options you need to meet your ad hoc reporting and query needs.
PRCSRUNCNTL
Set Up HMRS, System Administration, Database Processes, Refresh Personal Data, Refresh Personal Data
Refresh the Personal Data component. The Refresh Personal Dat component (PERS_REFRESH) loads the data types that you selected on the PERSONAL_DATA Settings page.
PRCSRUNCNTL
Set Up HMRS, System Administration, Database Processes, Update Personal Data-Future, Update Personal Data-Future
Run this process shortly after midnight to update the Personal Data component. The process will update data with future dated information that has become current.
The Update Personal Data-Future process runs the HR_PERSDATA application engine program.
Name Display Refresh
NAME_DISPLAY_RC
Set Up HRMS, System Administration, Database Processes, Refresh Name Display Values, Name Display Refresh
Refresh all records with the NAME_DISPLAY and NAME_FORMAL fields to reflect changes made to the PeopleCode definition of those fields. You can choose to update records with all name format types or just with one name format type.
HR Core Integrity Audit
HRAUDIT
Set Up HRMS, System Administration, Database Processes, Core HR Data Integrity Audit, HR Core Integrity Audit
Initiate the Core Human Resources Data Integrity Audit.
Click to jump to top of pageClick to jump to parent topicRefreshing the Employees Table
Access the Parameters page.
Click to jump to top of pageClick to jump to parent topicSelecting Refresh Options for the Personal Data Component
Access the PERSONAL_DATA Settings page.
Address Type
Select which address type to refresh.
Other Address Type
Select a secondary address type to refresh.
Include Installed Countries
Select to include the information in the country-specific group boxes for those countries that you've installed on the Installation Table - Country Specific page.
Include Primary Phone Data
Select to include the information in the PERSONAL_PHONE record.
Include Smoker Data
Select to include the information in the PERS_SMOKER record.
Include Campus Solutions Data
Select to include the information in the PERSON_SA record.
Include US Federal Data
Select to include the information in the PERS_DATA_USF record.
See Also
Adding a Person
Click to jump to top of pageClick to jump to parent topicRefreshing the Personal Data Table
Access the Refresh Personal Data page.
Click to jump to top of pageClick to jump to parent topicRefreshing the Personal Data Table with Future-Dated Data
Access the Update Person Data-Future page.
Click to jump to top of pageClick to jump to parent topicRefreshing Name Display Values
Access the Refresh Name Display Values page.
Select which records whose name fields format you want to update.
Click to jump to top of pageClick to jump to parent topicAuditing Human Resources Data for Integrity
Access the HR Core Data Integrity Audit page.
Select the HR tables you want to audit for integrity.
Click to jump to parent topicUsing the Tables Accessed and Updated Report
This section describes the Tables Accessed and Updated report.
Click to jump to top of pageClick to jump to parent topicUnderstanding the Tables Accessed and Updated Reporting Utility
The Tables Accessed and Updated report:
Use this information to:
Troubleshooting the Tables Accessed and Updated Report
Because of the flexibility of the programming environments and the rich set of meta-SQL available in PeopleTools, the table list created by the Tables Accessed and Updated report may sometimes be incomplete. The list will be incomplete when:
Click to jump to top of pageClick to jump to parent topicPage Used to Run the Table Access and Updated Report
Page Name
Object Name
Navigation
Usage
TAU_RUN_CONTROL
Set Up HRMS, System Administration, Utilities, Tables Accessed and Updated, Tables Accessed and Updated
Use the Table Access Utility page to run the Tables Accessed and Updated report.
Click to jump to top of pageClick to jump to parent topicRunning the Tables Accessed and Updated Report
Access the Tables Accessed and Updated page.
Application Type
Select the type of application to analyze in the report. The options are:
  • AppEngine Programs
  • SQR Reports
  • COBOL programs
  • Queries
Product
To restrict the analysis to applications in on product, select it here.
Application Name
Enter part or all of the name of the application or applications you want to analyze. Enter a ? to report on all applications in the product.
Note. Depending on the application type, there could be over a thousand applications in a product.
You can run the report using just the information you enter here or you can use this value as search criteria to create a list of applications using the Available Applications and Selected Applications group boxes.
For example, when you select SQR Reports, Human Resources, and enter R in the Application Name field and run the utility, the report will analyze the REG001FR, REG002FR, and REG003FR reports. To refine the search, click the Refresh Available Applications button and select which of the three reports to analyze and add them to the Selected Applications list.
Refresh Available Applications and Available Applications
Click Refresh Available Applications to populate the Available Applications group box with applications that match the search criteria you entered in the Application Name field. Select the applications you want to analyze.
Note. A small number of applications are not associated with normal run control pages (for example, one-time conversion routines or system setup utilities used during installation) and the system will not display them in the Available Applications list. You can enter these applications in the Selected Applications list using the insert button and entering the application's name.
Add
Click to add the applications you selected in the Available Applications list to the Selected Applications list.
Once you've added items to the Selected Applications list, you can enter new search criteria in the Application Name field and refresh the Available Applications list.
Clear Selected Applications and Selected Applications
The report will analyze all the applications included in the Selected Applications list. You can add or remove applications using the insert and delete icons.
Click the Clear Selected Applications button to clear the list of applications you've selected for analysis.
Include PeopleTools Tables
Select to include PeopleTools tables in your analysis. PeopleTools tables define all PeopleSoft objects and manage system behavior, and include this such as related language control, currency conversions, and Process Scheduler activity.
Location of Source Code
If you are analyzing COBOL programs, enter the path to the COBOL source code's location on the server.
Note. The system only makes this field available when you select to analyze a COBOL program.
Location of Tools programs
If you are analyzing SQR programs and are excluding PeopleTools tables, enter the path to the PeopleTools SQR components' location on the server.
Note. The system only makes this field available when you select to analyze SQR reports.
Click to jump to parent topicTesting Component Interfaces Using the Invoke Core CIs Utility
This section describes how to test component interfaces.
Click to jump to top of pageClick to jump to parent topicPages Used to Test Component Interfaces Using the Invoke Core CIs Utility
Page Name
Object Name
Navigation
Usage
Invoke Core CIs
RUNCTL_CCI
Set Up HRMS, System Administration, Utilities, Invoke Core CIs, Invoke Core CIs
Use this page to launch a component interface with sample data to test if it executes in the manner in which you want it to.
Error Log
RUNCTL_CCI2
Set Up HRMS, System Administration, Utilities, Invoke Core CIs, Error Log
After invoking a component interface, use this page to review any errors.
Click to jump to top of pageClick to jump to parent topicTesting Component Interfaces
Access the Invoke Core CIs page.
CI Access Information
Component Interface Name
Select the name of the component interface you want to test.
Invoke CI
When you've entered all of the necessary information, click to invoke the CI and test it using the information entered on this page.
CI Access Mode
Select one of the following access modes:
  • Create: Select to create a new row of data in the component with the key values that you enter in the Component Interface Access Keys grid.
  • Find: Select to find a list of data rows that match the search criteria you enter in the Component Interface Access Keys grid.
  • Get: Select to find a single row of data that match the search criteria you enter in the Component Interface Access Keys grid.
Write Log File
Select to create a log file of the component interface test.
Sort Order, KeyProperty, and Value
The component interface's key properties are the search keys of the underlying component's search record. Select with key fields to use in the search in the KeyProperty field and enter the value of the field to use in the search in the Value field.
If you are searching by more than one key field, indicate the order in which the system should sort the results.
If you are testing the CI using the Create action mode, use all the key properties.
Actions to Be Performed
Sequence Number
Indicate the order in which the system should execute this action using the component interface.
Action
Select the action to invoke using the CI:
  • Delete: Select to delete data rows that match the values you enter in this group box.
  • Get: Select to retrieve data rows that match the values you enter in this group box.
  • Insert: Select to insert a new data row with the values you enter in this group box.
    For example, if the current row is dated November 12, 2005 and you want to enter a row effective January 1, 2004 while still maintaining the November row as the current row, select this option.
  • Invoke Method:
    Select to execute the method for the CI. A method, for instance, can execute PeopleCode. For example, in Salary Planning, the calculation of the salary increase of each employee can be executed on-line or using a batch program. The bact program will execute the method CI_SALARY_PLAN_GRP.Methods.SalPlanGrp.
  • Update: Inserts a new, effective dated row in effective-dated components or updates the data in components that are not effective dated.
  • Update no Insert: Select to update the existing row of data.
Carry Forward
Select this option to update any rows in the component that are more current than the row you are inserting using the CI.
Parent Collection Name
Select the collection (which corresponds to a record) in which you want to update data.
(Collection Keys) Select the key field or fields for the scroll and enter the value of the row upon which you want to execute the action.
Sort Order, Property, and Value
(Property/Values Pairs) Select the fields in the collection and the field values that you want to use in the action.
