| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You access the currency calculator, shown in Figure 3-8, by clicking the calculator button that appears in currency or amount fields. You use the currency calculator to specify financial transaction information in foreign currencies. Table 3-2 describes each field control found in the currency calculator.
Table 3-2 Description of Currency Calculator Fields
| Field | Field Control | Description |
Currency Code |
Single select button |
Launches a dialog box where you can select the country and currency code. |
Exchange Date |
Calendar select button |
Launches the calendar control where you can pick the exchange date. For more information about the calendar control, see "About the Calendar Control". |
Amount |
Calculator button |
Type the amount in the field, or use the pop-up calculator, shown in Figure 3-9, to enter the amount. |
