| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
The screen tabs that appear in the application window are determined by your organization and might be only a subset of the available screen tabs. You access a screen by clicking the related screen tab, or by using the Site Map.
If the application you require is not displayed on a screen tab, you can set up your own screen tab for quick access to the application you want. For more information about how to set up your own screen tab, see "Showing, Hiding, and Reordering Screen and View Tabs".
To see a listing of all the screens available to you, use the Site Map.
To navigate to a screen using the Site Map
Do one of the following:
From the application-level menu, choose Navigate, then Site Map.
Click the Site Map button on the application toolbar.
In the Site Map, click the hyperlink for the screen you want to navigate to.
The Site Map displays the screen and all the views available in that screen.
Note: If you select a screen or view from the Site Map that does not appear as a screen tab or a view tab in your application, a screen tab or view tab is created when you jump to that screen or view. It will only be visible for the current session. |
Click the hyperlink to jump to the screen or view.
Related Topic
