| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
Use the controls that appear in the upper right corner of each list and form to change the layout of your application home page. The changes you make to the layout using these controls, described in Table 13-1, remain in effect until you change the layout again.
Table 13-1 Home Page Controls
| Button | Description |
Hides the list or form and temporarily removes it from the home page. Note: You must edit the layout of the home page to place the list or form back on the home page. |
Collapses the list or form to its minimal size showing no records. |
Expands the list or form to its standard size. |
