| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You might find that you want to cancel edits you have made to a record before you save it. You can undo your edits to a record only if you have not saved it yet.
To cancel edits in form or a list
Click the menu button, and then click Undo Record.
Note: You cannot undo changes or additions that you make to selection dialog boxes. For example, when you add or remove employees from a selection dialog box, you cannot undo these changes. |
