| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can get an accurate count of the number of records in a list without having to navigate to the last record in that list. If you execute a query, this function will show you the total number of matching records in the query.
To display record count
(Optional) Execute a query.
Click the menu button, and then click Record Count.
The Record Count dialog box appears.
If you did not execute a query, this dialog box shows the total number of records in the active list.
If you executed a query, this dialog box shows the total number of records that match your current query criteria.
