| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You might find that you want to alter the width of a column to better view data. You can also save a changed column size so you do not have to resize a column repeatedly.
To resize columns
Place the cursor over the column header divider.
A resize arrow appears.
Click and drag the column divider to the right to widen the column, or to the left to narrow the column.
