| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can specify which time zone your Siebel application uses to display date and time fields during your session.
To set a default time zone
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
On the link bar, click Profile.
The Profile form appears.
In the Time Zone field, click the select button.
The Pick Time Zone dialog box appears.
Select the desired time zone and click OK.
Note: In order for calendar alarms to work correctly, make sure that your computer's time zone setting is the same as the time zone you select in Step 4. |
