| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
Throughout your application, you might come across various screens in which you can invoke an HTML editor.
Your user preferences must be set up to allow you to use the HTML editor in the Send Email dialog box. For more information, see "Setting Outbound Communications Preferences for Send Email".
The HTML editor provides special editing controls that allow you to use supported HTML formatting, and also provides some standard editing features such as cut and paste. Table 11-1 describes each button available in the HTML Editor toolbar.
Some buttons might not be available, depending on where in the application you are when you launch the editor.
Table 11-1 HTML Editor Toolbar Button Descriptions
| Button | Name | Description |
Align Center |
Click to center each line of selected paragraphs. |
Align Left |
Click to left-align selected paragraphs. |
Align Right |
Click to right-align selected paragraphs. |
Bold |
Click to apply bold formatting to selected text, or to remove bold. |
Bullets |
Click to apply bullets to selected text, or to remove bullets. Creates a list of bulleted paragraphs, corresponding to an HTML unordered list. Bullets appear differently at different levels of indenting. Note: Items that are at the same indentation level within a list must have the same list type, either all items bulleted or all items numbered. List items that are at different indentation levels can have different list types. This means you can nest an indented list of one type (such as a bulleted list) within a list of another type (such as a numbered list). |
Copy |
Click to copy selected text to the clipboard. |
Cut |
Click to cut selected text to the clipboard. |
Decrease Indent |
Click to decrease the indenting for selected paragraphs. |
Embed Image |
Click to embed an image in the document. |
Embed Link |
Click to embed a link in the document. |
Find/Replace |
Click the arrow to the right of the binoculars to display the Find controls. The Find controls appear above the editing bar. Click the arrow on the left side of the Find controls to toggle between Find controls and Find and Replace controls. To find specified text, enter the text to find in the Find field, and then click Go.
To replace specified text, enter the text to replace in the Replace field. Enter the replacement text in the with field. If you want to replace all instances of the specified text, select the Replace All check box and then click Go. ![]() |
Font |
Choose a font from a drop-down menu to apply to selected text. Available fonts include Arial (the default), Verdana, Times New Roman, and Courier. |
Font Color |
Click the arrow to display font colors above the editing bar, and then click to choose a color to apply to selected text. The line beneath the letter A indicates the currently selected font color. |
Font Size |
Choose a size from a drop-down menu to apply to selected text. Point sizes include 8 (the default), 10, 12, 14, 18, 24, and 36. |
Increase Indent |
Click to increase the indenting for selected paragraphs. |
Italic |
Click to apply italic formatting to selected text, or to remove italics. |
Numbering |
Click to apply numbering to selected text, or to remove numbering. Creates a list of numbered paragraphs, corresponding to an HTML ordered list. Note: Items that are at the same indentation level within a list must have the same list type, either all items bulleted or all items numbered. List items that are at different indentation levels can have different list types. This means you can nest an indented list of one type (such as a bulleted list) within a list of another type (such as a numbered list). |
Paste |
Click to paste text from the clipboard into the message area. Depending on the source, text you paste might include HTML formatting. |
Underline |
Click to apply underlining to selected text, or to remove underlining. |
