| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can view only calendars to which you have been granted access. If you are a manager, you can view the calendars of your direct reports.
To view another user's calendar
Navigate to the Calendar screen.
From the Owner drop-down list, choose the user of the calendar you want to see.
The calendar refreshes to display the other user's calendar.
Tip: If your job often requires you to access another user's calendar, you might want to set up that user's calendar as your default calendar. This can be done from the User Preferences screen. For more information, see "Setting Up Another User's Calendar as Your Default Calendar". |
