| Siebel Customer Relationship Management Siebel Fundamentals Siebel Innovation Pack 2013, Version 8.1/8.2 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
The task UI is a wizard-like user interface that:
Guides you through task execution
Allows you to navigate back and forward during the task execution
Allows you to resume or pause task execution at any point
For more information about Task UI, see Siebel Business Process Framework: Task UI Guide.
Task UI features help increase the efficiency of:
Novice or intermittent users by guiding them through the execution of unfamiliar tasks
Experienced users who want to switch between multiple tasks throughout their working day
The task UI includes the following features that support task execution:
Tasks Pane. The left side of the screen contains a context-sensitive listing of the tasks available to you. These tasks relate to the current context. When you select a given task, the Tasks Pane shows the sequence of steps for that task.
Playbar. The Task screen has a standard set of four buttons that control navigation through the task flow. It includes buttons to move forward and back through the steps and provides the ability to pause a task for later resumption or cancel a task. For more information about the navigational buttons, see "Navigational Buttons for Task UI".
Radio Buttons. Radio buttons provide support for decision-making within a task. Based on the choices within a task, you can access different branches and different screens.
After you launch a Task item, it remains active until you end it. This action means that if you launch Tasks, and then navigate to a different screen, the Task steps do not change.
