Siebel Object Interfaces Reference > Siebel Object Interfaces Reference > Format of the Object Interface MethodThis topic describes formats for object interface methods, arguments, and return values. A Siebel object interface method uses the following format: ObjectType.MethodName(arg1[, arg2, ..., argn])
Note how this book uses the following terms:
Formats for Siebel VBIf there is a return value, then use the following format: returnValue = ObjectReference.MethodName(arg1, arg2, ..., argn) If there are no arguments, then use the following format: returnValue = ObjectReference.MethodName If there is no return value, then use the following format: ObjectReference.MethodName arg1, arg2, ..., argn The following examples use Siebel VB: acctName = acctBC.GetFieldValue("Name") Formats for Siebel eScriptIf there is a return value, then use the following format: returnValue = ObjectReference.MethodName(arg1, arg2, ..., argn); If there are no arguments, then use the following format: returnValue = ObjectReference.MethodName(); If there is no return value, then use the following format: ObjectReference.MethodName(arg1, arg2, ..., argn); The following examples use Siebel eScript: acctName = acctBC.GetFieldValue("Name"); Formats for the Component Object ModelThe format that Siebel CRM uses for the Component Object Model (COM) depends on the language you use to call the COM interface. For Microsoft Visual Basic and equivalent languages, the format is similar to the format you use for Siebel VB, except that if you use COM Data Control, then Siebel CRM passes an error code as the final argument. |
| Siebel Object Interfaces Reference | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
