Siebel Product Administration Guide > Product and Promotion Eligibility and Compatibility > Defining Eligibility for Products with Components and for Component ProductsEligibility for products with components is checked at the following times:
Eligibility for products with components is defined in the same way as eligibility for other products:
If you define eligibility for component products, the customer may not be eligible to buy all the default components of a product with components but may be eligible to buy the product with components with substitute components. In this case, the product with components can be flagged as ineligible, so customers can select substitutes for the default components that they are not eligible to buy. |
| Siebel Product Administration Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
