Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Interact with Conflicts and Messages >
GetExplanations Method
This method retrieves configuration explanations for an item.
Input Arguments
  • ObjId. The unique identifier of the complex object root (for example, Quote ID).
  • RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
  • Path. The path of the item.
Output Arguments
The property set returned will have child property sets, each with the property Value as the explanation, as follows:
<Output>
<Expl Value="Explanation"/>
</Output>
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
