Siebel Product Administration Guide > Multilingual Translations for Product Data >
Translating Configuration Rule Explanations
Use this procedure to translate configuration rule explanations for a customizable product.
To translate a configuration rule explanation
  1. Navigate to the Administration - Product, then the Product Definitions view.
  2. In the Products list, select and lock the desired customizable product.
  3. In the Versions list, click the Work Space version.
  4. Click the Constraints view tab.
  5. In the Constraints List, select the constraint containing the explanation you want to translate.
  6. From the Constraints List menu, choose Translate Constraint Description.
    A dialog box appears that displays the rule explanation translations you have already created.
  7. In the dialog box, add a new record and complete the necessary fields, described in the following table.
    Field
    Comments
    Language
    Displays the name of the language after you select the code.
    Code
    Select a language code.
    Description
    Enter the translation of the description.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
