Siebel Product Administration Guide > Configuration Constraints > Tuning Configuration Constraints > Sequence Number List ColumnThe Sequence Number List Column is used to decide the order of evaluation for both attributes and relationships. You can access the Sequence Number List Column for attributes through the applet menu option, Columns Displayed. The Sequence Number List Column is available for relationships in the standard Siebel application. The sequence number for relationships determines the UI display order when no UI option is defined. In case of conflicting requirements between a desired evaluation order and the UI presentation order, always favor the evaluation order requirements. It is always possible to change the UI presentation order by using UI Option, UI Group, and then UI Item structure. |
Siebel Product Administration Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
