Siebel Product Administration Guide > Testing Products and Using Workspace Projects > Process of Testing Products with Scenario Tester > Defining the Contents for Scenario TestingWhen you define the contents for the scenario, you specify all the products, attributes, classes, signals, and variable maps whose workspace versions will be tested. For these objects, the testing date from the joint workspace will not be in effect. For example, this list can include one customizable product plus all the component products, product attributes, and product classes that are part of that customizable product. In more complex cases, it can include several customizable products and component products, product attributes, and product classes that are part of it. This task is a step in Process of Testing Products with Scenario Tester. To define the contents for the scenario test
| Siebel Product Administration Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
