Siebel Security Guide > Communications and Data Encryption > Enabling SSL Acceleration for Web Server and Web Client CommunicationsThis topic describes how to configure SSL acceleration for communications between the Siebel Web server and Siebel Web Clients. This task is a step in Process of Configuring Secure Communications. If you are using a third party HTTP-based load balancer for your Siebel Server load balancing and you want to off-load the processing of SSL encryption and decryption algorithms to the hardware accelerator on your load balancer, then you must enable the EnforceSSL parameter. Doing so improves application performance and ensures that SSL is used to encrypt URLs. EnforceSSL is False by default. To enforce the use of SSL acceleration, you change the EnforceSSL parameter for an Application Object Manager to True.
| Siebel Security Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
