Siebel Database Upgrade Guide for DB2 for z/OS > Planning a Siebel Database Upgrade > Planning Resources for Upgrading to Siebel CRM Version 8.1 on z/OSThe chapter in Siebel Database Upgrade Guide that describes Siebel database and UI upgrade planning tasks also describes the planning resources available to you before you start to upgrade to Siebel CRM version 8.1. This topic describes additional resources available if you use Siebel Business Applications with DB2 for z/OS. DocumentationRead Implementing Siebel Business Applications on DB2 for z/OS, available on the Siebel Bookshelf, for information on configuring your Siebel application after you have upgraded to Siebel CRM version 8.1. About Oracle's Application Expert ServicesOracle's Application Expert Services offers detailed implementation planning and technical consulting services. Oracle recommends that you engage Oracle's Application Expert Services for help in planning your upgrade on DB2 for z/OS. Oracle's Application Expert Services can help you to:
For further information, see About Using Oracle's Application Expert Services. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
