Siebel Database Upgrade Guide for DB2 for z/OS > Basic Database Preparations for a Siebel Upgrade >
Updating Group Names
Upgrades: All upgrades. Environments: Development environment only. If you are upgrading to the current release, table space group names are not updated for some of the tables in the Siebel-supplied ddl.ctl file. You must update the table space group names so that they match the names used in the DB2 catalog; this ensures the repository group names are the same as those used in your physical database environment. To update table space group names
- To update the table space group names, execute the following query:
UPDATE SIEBEL.S_TABLE A
SET A.GROUP_CD = (SELECT B.TSNAME FROM SYSIBM.SYSTABLES B WHERE A.NAME = B.NAME AND B.CREATOR = SIEBEL)
WHERE A.INACTIVE_FLG = 'N' and A.REPOSITORY_ID = (SELECT B.ROW_ID FROM B.S_REPOSITORY WHERE B.NAME = 'Siebel Repository')
where SIEBEL is your Siebel schema qualifier name.
