Using Siebel Tools > Using Siebel Script Editors > Using the ST eScript Engine >
Using Fix and Go
If you enable Fix and Go, then you can edit a script in a Siebel Tools session, and then test your modifications in the Siebel client without closing this client or recompiling the script. This feature allows you to save time in script development, testing, and debugging. You can use Fix and Go only with a server script and the ST eScript Engine.
To use Fix and Go
  1. Enable Fix and Go in the Development Tools Options window.
    For more information, see Setting Options for the ST eScript Engine.
  2. Create a server script in the Siebel Script Editor, save it, and then compile the repository.
    If you attempt to save a script that includes a format error, then Siebel Tools displays a script error message that prompts you to fix the line or the lines that cause the error. For more information, see Compiling Your Modifications.
  3. Use the Siebel Debugger to run the script.
  4. If an error occurs, then stop the script.
  5. Make modifications, save your script, and then run it again.
    You must save and compile all script modifications before you exit Siebel Tools. If you do not save your modifications, then they are lost.
Using Siebel Tools Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
